Bosch GXL12V-220B22
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
Bosch GXL12V-220B22
Where are you going to buy it from? (I can only find it abroad, not to mention it looks like a toy)
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2305 times
Bosch GXL12V-220B22
bosch 10.8/12v [same tool same battery] are extremely good for the size
they are slightly lower geared to push above there weight but a bit slower
as said you need a uk kit rather than a us kit
Bosch GXL12V-220B22
I have a relative staying in the US, I can ask her to send it. Just checking the reviews and other options for now though.someone-else wrote: ↑Sun May 10, 2020 1:11 pm Where are you going to buy it from? (I can only find it abroad, not to mention it looks like a toy)
- Someone-Else
Bosch GXL12V-220B22
If you get it sent from the USA you will have no warrantee, you may have to pay import duty on it, if it does NOT have a "universal charger" it will be of little use.
You can also buy better here for the same money
- Has thanked: 775 times
- Been thanked: 3311 times
Bosch GXL12V-220B22
Just get an 18v cordless combi drill driver. It will cover most of your needs. Those small 12v tools are useless and there are very few jobs that it is practical for.
- big-all
- Pro Carpenter
Bosch GXL12V-220B22
interesting comments dwddewaltdisney wrote: ↑Thu May 14, 2020 1:50 pm Just get an 18v cordless combi drill driver. It will cover most of your needs. Those small 12v tools are useless and there are very few jobs that it is practical for.
modern 10.8/12v like bosch blue punch way above there weight
modern brushless motors give perhaps 20-30% more power in the same package whilst using less off the battery power
iff you add say 25% extra power to perhaps 20% lower gearing you get very close to the old standard for 18v but in 12v but a bit slower progress
Bosch GXL12V-220B22
I am sure that is the case All but this sounded to me like it was going to be the OP's only drill, I may have imagined that, and I was saying that the 18v would be a better all rounder with hammer action and two speeds.I am probably wrong
- big-all
- Pro Carpenter
Bosch GXL12V-220B22
yes indeed i agree an 18v would be better hence not recommending 12vdewaltdisney wrote: ↑Thu May 14, 2020 3:24 pm I am sure that is the case All but this sounded to me like it was going to be the OP's only drill, I may have imagined that, and I was saying that the 18v would be a better all rounder with hammer action and two speeds.I am probably wrong
all i would add is 12v is great for old aching bones and often fit in jean pockets so great for working at height
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
Bosch GXL12V-220B22
I have two of these type. They are great bits of kit.
I have the GSR108VECHXN. Bought in 2016 and gets plenty of use and still going strong. The second is similar but has a slightly longer handle. I can't remember the model name. I haven't touched it yet but the batteries are interchangeable.
Great quality.
Great quality.
