Hey guys I just completed my first pc build and am unsure how to hook up my graphics card to my tv. I'm currently waiting on my monitor to arrive but want to make sure everything is in working order and whatnot. My motherboard does all the checks and everything is good. I hooked up the graphics card with the HDMI port to the TV and it shows "no signal". I'm using a XFX Radeon RX 5700 XT 8 GB RAW II Video Card
Many thanks
How to hook up graphics card to monitor
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
That is probably because it is a TV and as such needs to be told to look at the HDMI port for a signal.
Look at you TV remote control and look for a "source" (or similar button) and select HDMI,
- Has thanked: 94 times
- Been thanked: 857 times
Have you installed windows or an operating system ? on first boot it will default to either onboard graphics or the display port, depending on how the bios is setup
Hopefully your new monitor has displayport if not you will need an adapter
