Old power tool issue, fixable?
- Has thanked: 32 times
- Been thanked: 788 times
ok i worded it bad before as ive been between jobs. the part you point at is the commutator. the carbon brushes are serviceable parts that press onto that. they are what those wires were connected too. they provide power to the armature to make the motor work. take out the carbon brushes and you should be able to slide the armature out. thats normally how it would work
Morning,
Its definitely 110v as its got a yellow lead and I have to use a transformer, plus it says 110v on the tool :)
I tried removing the carbon brushes and the brush holder (16) at the back of the machine but the armature still didn't seem to want to come out. The part 64 is called a locking ring apparently so my guess is that needs to be removed as well, but I couldn't figure out how to do that last night although I recon its just very tight and I will have to use something to grip both bits and counter turn. If anyone has a good method without damaging I'm all ears.
- Screenshot 2020-04-14 at 09.44.44.png (661.44 KiB) Viewed 1644 times
Cheers for the help. Managed to get the armature off just by pulling it hard enough as it was around some rubber at the end. The hard part not now finding the correct armature which I can't seem to find as its an older model. Oh well worth a try.
Cheers
E
Cheers
E
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2309 times
another thought
choose the same model from ebay spares or repairs and choose one with a different fault
