Afternoon
I have a problem with pitted and mottled plasterboard walls. Not terrible but not what I want to paint over. I need to smooth the entire wall.
They just have old white emulsion on them
I asked a plasterer if he would skim it for me.
He advised I could do this my self buying a few bags of gyproc easifill. Skim the entire wall with a roller and smooth out with a knife.
Has anyone done this? The spread said it's the easiest way for the diy'er who doesn't plaster
Can you just go straight onto the painted wall with the filler?
Does it need a mist coat after?
What grit sandpaper and would you use an orbital sander?
Thanks in advance
Lordyjordy
Easifill
- Has thanked: 775 times
- Been thanked: 3317 times
Easifill
I did a chimney breast in Easifill. The trick is to stop the wall sucking all the water out of the Easifill to give you time to work it. I wetted the wall as I was going with a roller dipped in water. Easifill is very nice to work if you mix it up into a thin cream, not too thin though. Work quickly using a hawk and a plasterers trowel, smooth it over getting it as good as you can get near to finish as you go. This cuts down the sanding to get it all uniform when it is dry. It sands easy but makes a lot of dust.I would experiment on a smaller area first to get the hang of it. From the sounds of it the imperfections are not too deep so it should be okay.
- Has thanked: 100 times
- Been thanked: 1022 times
Easifill
Never heard of applying it with a roller before.
As a filler I really like easifill and it is my main filler. Mixed to a light paste it is nice to work with and easy to sand. I treat it a little bit like you would plaster, spread it out, let it start to firm up and use a moist trowel to smooth it out, minimal sanding afterwards.
- Has thanked: 283 times
- Been thanked: 397 times
Easifill
I think the plasterer was referring to this
https://www.wickes.co.uk/Knauf-Proroll- ... g/p/166799
You roll it on and smooth it out with a trowel or taping knife.
Mike
Mike
