Hi, I am working on a project using 9mm plywood. I've cut the bits to the correct shape & size but yesterday noticed that they are both quite badly warped.
Laid both sheets flat on the floor overnight with heavy weights on them but it doesn't seem to have done any good. The two sheets are approx. 4ft x 2ft in size (each).
Are there any tricks of the trade I can use to flatten the sheets?
Many thanks
How to flatten warped plywood
- Has thanked: 775 times
- Been thanked: 3314 times
A narrow chock under each end and weigh the middle down. You will cause an overbend but it should cure the memory spring back.
- Croker (Sun Mar 15, 2020 3:33 pm)
- Has thanked: 118 times
- Been thanked: 21 times
Brilliant!
DWD to the rescue, and not for the first time either. I am very grateful
Will do exactly as you've suggested and leave them again overnight.
Again, many thanks!
Again, many thanks!
Update... your tip has worked nicely DWD
Unfortunately what I thought was going to be a fairly simple exercise has turned into 'one of those' jobs... however, at least I've got time to work on it thanks to Coronavirus!
- These users thanked the author Croker for the post:
- dewaltdisney (Sat Mar 21, 2020 5:48 pm)
