about time i had a new lap top i think ??
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2306 times
a 6 year +old toshiba satelite 150 a 1dv intel core 13 windows [8]now 10
dont do gaming or any work or store anything on it
do shopping web searches watch perhaps 2hrs catchup tv a day and very little else
now working on the principal i could get somthing twice as good for half the possible £450 i paid for it
now i dont want swishy setups i want it to operate as near looking to windows xp will be usingfirefox and duck duck go
needs to take a mouse and have monitor connection
any suggestions please
- etaf
- Has thanked: 37 times
- Been thanked: 137 times
i3 are still good value not aure you will get the extra performance for £200 , I looked for a collegue in UK recently and saw that i3/i5/i7 CPUs have not changed that much in price since windows 7
an i3 with 4gb ram is probably good for general use and as on windows 10 , you should be OK
i often get i5 with 8GB ram and thats fine for some graphica
BUT i have now moved to Apple laptop and far better than a windows 10 PC , but a lot of money
have a look at johnlewis & currys and see what you can buy
I use this site for CPU comparison
https://www.cpubenchmark.net/cpu_list.php
But be careful, i3 v i5 is not always better, check the exact model
alos they are now moving to ssd harddrives, with a much smaller capacity , 256gb typically - which if you store a lot of videos/movies may mean having an external harddrive or cloud storage
see how much space you currently use up
why changing ?
why changing ?
Simple DIYer
Wayne
Wayne
- big-all
- Pro Carpenter
thanks for that
it probably wont mater iff its same or perhaps 25% as a clean install will always be devoid off the junk i dont know thats there
- etaf
you can do a clean install on your laptop if you wanted to
Do you need a dvd , few have them now
have a look and see what i3 you have now
and also RAM
https://www.howtogeek.com/413942/how-to ... ast-it-is/
clean install windows 10
https://www.howtogeek.com/224342/how-to ... indows-10/
and also RAM
Simple DIYer
Wayne
Wayne
- big-all
- Pro Carpenter
cpu is reading between 6-23%
memmory about 79%
disc 3%
what ever that means
memmory about 79%
disc 3%
- etaf
sorry i meant the actual model of the i3
some i5 are slower than i3, hence the warning
memory RAM amount, should be shown, in GB
and harddrive usage, as mentioned , cheaper machines are 128GB or 256GB harddrive SSD drives now
and the budget , is it £450 still? or half that ? £225
Simple DIYer
Wayne
Wayne
- big-all
- Pro Carpenter
satellite is that the model
- big-all
- Pro Carpenter
intel[r] core[tm]i3-3110mcpu'@2.4gh
- etaf
https://www.cpubenchmark.net/compare/In ... /763vs3349
so the later i3 will be better performance
However, as requested before , whats the RAM, how much storage do you need, do you need a DVD and also your budget
Simple DIYer
Wayne
Wayne
- big-all
- Pro Carpenter
not bothered if it costs nearer to £450 than £250 never used the cd indeed it was only 2 years ago when i found it had one and then it wouldnt work anyway
dont need any storage that i know off there wiill be perhaps 100-200 pictures tranfered from my phone but nothing else the only files i will have is when you download a bill or timetable
dont know how to make a file
dont have any programs or films
sorry iff my answers seem disjointed and miss the end off your posts as i have my screen on 150% i only get seven lines or half your posts and forget to scroll
- etaf
heres a i5 machine at john lewis
https://www.cpubenchmark.net/compare/In ... /763vs3542
much faster CPU
£500
https://www.johnlewis.com/asus-vivobook ... r/p4852163
14" screen
but there are others
https://www.johnlewis.com/dell-inspiron ... r/p4892423
i would suggest a clean install and see how it works
What is wrong with the current laptop, whats it NOT doing that you want it to do - just before you throw £500 at it
much faster CPU
£500
14" screen
Simple DIYer
Wayne
Wayne
- big-all
- Pro Carpenter
its just getting old with the letter"i" playing up and the scroll down button has done a runner
iff i do a clean install will it effect the general firefox look or just the bit when you press the windows button ??
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
If you do a clean install, it will remove Everything.
Did you know you can plug a keyboard and mouse into a laptop? (I have a wireless mouse on mine, as I can't get along with the scroll pad)
