A while back we bought a TV bracket for a large TV by searching for the TV model number, when it arrived it became obvious that the bracket would not work with the TV, so these stretcher plates, or bracket adaptors were made to enable the bracket would fit the TV. The plates are made from 10mm thick aluminium and took about ½ day to make including painting and filming the video etc.
- Metalworking videos
- TV bracket adapters
How to use an Helicoil to repair a damaged thread
by admin 1,864 Views -
How to make a monitor wall bracket | HP monitor wall bracket
by admin 690 Views -
Cutting threaded bar
by admin 1,539 Views -
How to make brackets | Angle brackets
by admin 2,309 Views -
How to fit a shower fixing bracket
by admin 4,400 Views -
Drilling hardened steel with ARTU drill bits
by admin 2,396 Views -
Left handed drill bit to remove broken studs
by admin 2,812 Views -
Choosing a disk for a grinder
by admin 2,078 Views -
How to use a screw extractor/easyout
by admin 2,998 Views -
Removing a broken bolt using a welder
by admin 2,802 Views -
by admin 32.5k Views -
by admin 25.9k Views -
by admin 18.5k Views -
by admin 10.1k Views -
by admin 5,631 Views -
by admin 7,338 Views -
by admin 8,091 Views -
by admin 8,808 Views -
by admin 7,524 Views -
by admin 4,309 Views
