Dewalt DWS780 | 12 inch double bevel sliding mitre saw
The Dewalt DWS780 is a 12 inch double bevel sliding mitre saw, the blade is 305mm or 12 inches. This sliding mitre saw has a 1675w motor and is powerful enough to cut the hardest timber. This mitre saw uses XPS technology to illuminate the blade, which creates a shadow directly where the blade will cut, this is much more accurate than a laser and will never require calibrating (unlike a laser). The Dewalt DWS780 has 5 speed settings, which means you can cut harder materials at slower speeds when required. The maximum cross cut at 90 degrees is 349mm, although by using a 38mm deep board you can cut up to 16.1 inches (409mm). This machine will cut through the hardest of timbers with ease and will give very accurate cuts when used by a skilled operator. You can find these machines for sale on ebay- http://fave.co/1mNntE1
Dewalt 12" mitre saw, Dewalt DWS780
