Woodworking videos
Woodworking how to videos
This section has videos showing how to work with wood. Many people prefer working with wood as it is much warmer and easier to work than metal. The videos in this section will show how to cut, join and finish wood including MDF
  • 07:42 Popular How to make a Feather edge garden gate
    by Admin Added 9,189 Views / 0 Likes
    An inexpensive way to make a garden gate is using some tantalised 4*2 timber and some feather edge boards. You can easily make a garden gate to your required size easily using this method.
  • 12:02 Popular Installing a stud ceiling
    by Admin Added 3,315 Views / 0 Likes
    How to create a false ceiling using 3*2 timber
  • 04:14 Popular How to Ply line a floor
    by Admin Added 3,271 Views / 1 Likes
    Before tiling a floor it is often necessary to strengthen the floor using a sheet material such as WBP plywood or tile backer board. This video demonstrates how to fix WBP plywood to a tongue and groove wooden floor.
  • 17:22 Popular How to make a wood garden gate
    by Admin Added 2,526 Views / 1 Likes
    This wooden gate can easily be made in a few hours. This gate is made from redwood and is glued and screwed together using external wood glue and external wood screws.
  • 02:46 Popular Cutting timber squarely using a circular saw
    by Admin Added 2,500 Views / 1 Likes
    Cuttingtimber squarely is often essential when building things with timber. If you arelucky enough to have a chop saw that can accommodate the piece of timber youcan easily cut it squarely, but for people that don’t here is how to make asimple guide
  • 04:32 Popular How to make a mitre joint
    by Admin Added 2,435 Views / 0 Likes
  • 01:58 Popular Angle grinder to shape wood
    by Admin Added 2,408 Views / 0 Likes
    Wood can easily and quickly be shaped with an angle grinder using a flexible sanding pad and abrasive disc. In this video I scallop a piece of wood using this technique. This is also a fast and efficient way of removing excess timber, or rounding off shar
  • 03:24 Popular How to Under cut door frames
    by Admin Added 2,254 Views / 0 Likes
    Under cutting door frames is a good way of getting any flooring underneath existing architrave and door frames/skirting board etc.
  • 02:31 Popular How to use hinge drills
    by Admin Added 2,232 Views / 0 Likes
    Hinge drills or hinge siting drills are a very useful drill for ensuring that the screw pilot hole is drilled in the dead centre of the hinge fixing hole. Please ensure that you do not buy a cheap set of these as they will not work as well as a decent qua
  • 14:11 Popular Airing cupboard shelving
    by Admin Added 2,166 Views / 0 Likes
    This video shows how to install shelving and clothes rails into a disused airing cupboard.
  • 02:16 Popular How to fit internal door handles
    by Admin Added 2,165 Views / 0 Likes
    How to install internal door handles
  • 04:01 Popular How to use a screw digger
    by Admin Added 2,037 Views / 0 Likes
    How to use a screw digger and plug cutter to conceal screw heads in timber.
  • 06:38 Popular How to use a biscuit joiner
    by Admin Added 2,016 Views / 2 Likes
    A biscuit joiner, sometimes called a biscuit jointer or plate jointer is useful when making widening joints.
  • 01:49 Popular Lubricate wood screws
    by Admin Added 1,927 Views / 0 Likes
    When driving wood screws you can reduce friction and make the screws drive in much faster if you lubricate the screws first
  • 09:47 Popular Overhead garage rack
    by Admin Added 1,780 Views / 0 Likes
    This video shows how to make useful rack or hanger that fits in the roof space above a garage door, this space is often wasted and can be easily utilised using this method. To make these hangers 3*2 timber was used, which was joined using biscuit joints r
  • 15:26 Popular Making a fence panel
    by Admin Added 1,740 Views / 0 Likes
    Making a fence panel can be an enjoyable DIY job, here we make a 6 foot panel from feather edge boards
