Woodworking videos
Woodworking how to videos
This section has videos showing how to work with wood. Many people prefer working with wood as it is much warmer and easier to work than metal. The videos in this section will show how to cut, join and finish wood including MDF
  • 14:11 Popular Airing cupboard shelving
    by Admin Added 2,220 Views / 0 Likes
    This video shows how to install shelving and clothes rails into a disused airing cupboard.
  • 01:58 Popular Angle grinder to shape wood
    by Admin Added 2,458 Views / 0 Likes
    Wood can easily and quickly be shaped with an angle grinder using a flexible sanding pad and abrasive disc. In this video I scallop a piece of wood using this technique. This is also a fast and efficient way of removing excess timber, or rounding off shar
  • 02:46 Popular Cutting timber squarely using a circular saw
    by Admin Added 2,554 Views / 1 Likes
    Cuttingtimber squarely is often essential when building things with timber. If you arelucky enough to have a chop saw that can accommodate the piece of timber youcan easily cut it squarely, but for people that don’t here is how to make asimple guide
  • 10:24 Popular How to build a picture frame deck
    by Admin Added 974 Views / 0 Likes
    A picture frame deck can make a decking project look much neater as it creates a frame around the edge of the deck so that no cut ends are visible. In this video a single frame is used but you can use a few frames on a single deck to get the effect that y
  • 04:29 Popular How to fit a door viewer | spy hole
    by Admin Added 1,772 Views / 0 Likes
    This video shows how to quickly install a door viewer (often called a spy hole) into a solid wood door.
  • 06:04 Popular How to fit a letter plate
    by Admin Added 1,087 Views / 0 Likes
    How to fit a letter plate into a wooden door
  • 02:16 Popular How to fit internal door handles
    by Admin Added 2,244 Views / 0 Likes
    How to install internal door handles
  • 03:23 Popular How to make a Butt joint
    by Admin Added 1,804 Views / 0 Likes
    This demonstration shows how to make one of the simplest woodworking joints, the butt joint.
  • 07:42 Popular How to make a Feather edge garden gate
    by Admin Added 9,243 Views / 0 Likes
    An inexpensive way to make a garden gate is using some tantalised 4*2 timber and some feather edge boards. You can easily make a garden gate to your required size easily using this method.
  • 04:32 Popular How to make a mitre joint
    by Admin Added 2,534 Views / 0 Likes
  • 17:22 Popular How to make a wood garden gate
    by Admin Added 2,583 Views / 1 Likes
    This wooden gate can easily be made in a few hours. This gate is made from redwood and is glued and screwed together using external wood glue and external wood screws.
  • 04:14 Popular How to Ply line a floor
    by Admin Added 3,337 Views / 1 Likes
    Before tiling a floor it is often necessary to strengthen the floor using a sheet material such as WBP plywood or tile backer board. This video demonstrates how to fix WBP plywood to a tongue and groove wooden floor.
  • 03:24 Popular How to Under cut door frames
    by Admin Added 2,302 Views / 0 Likes
    Under cutting door frames is a good way of getting any flooring underneath existing architrave and door frames/skirting board etc.
  • 06:38 Popular How to use a biscuit joiner
    by Admin Added 2,069 Views / 2 Likes
    A biscuit joiner, sometimes called a biscuit jointer or plate jointer is useful when making widening joints.
  • 04:01 Popular How to use a screw digger
    by Admin Added 2,071 Views / 0 Likes
    How to use a screw digger and plug cutter to conceal screw heads in timber.
  • 02:31 Popular How to use hinge drills
    by Admin Added 2,317 Views / 0 Likes
    Hinge drills or hinge siting drills are a very useful drill for ensuring that the screw pilot hole is drilled in the dead centre of the hinge fixing hole. Please ensure that you do not buy a cheap set of these as they will not work as well as a decent qua
