Woodworking videos
Woodworking how to videos
This section has videos showing how to work with wood. Many people prefer working with wood as it is much warmer and easier to work than metal. The videos in this section will show how to cut, join and finish wood including MDF
  • 06:38 Popular How to use a biscuit joiner
    by Admin Added 2,017 Views / 2 Likes
    A biscuit joiner, sometimes called a biscuit jointer or plate jointer is useful when making widening joints.
  • 04:14 Popular How to Ply line a floor
    by Admin Added 3,273 Views / 1 Likes
    Before tiling a floor it is often necessary to strengthen the floor using a sheet material such as WBP plywood or tile backer board. This video demonstrates how to fix WBP plywood to a tongue and groove wooden floor.
  • 17:22 Popular How to make a wood garden gate
    by Admin Added 2,527 Views / 1 Likes
    This wooden gate can easily be made in a few hours. This gate is made from redwood and is glued and screwed together using external wood glue and external wood screws.
  • 02:46 Popular Cutting timber squarely using a circular saw
    by Admin Added 2,504 Views / 1 Likes
    Cuttingtimber squarely is often essential when building things with timber. If you arelucky enough to have a chop saw that can accommodate the piece of timber youcan easily cut it squarely, but for people that don’t here is how to make asimple guide
  • 00:40 Popular Treating cut ends
    Treating cut ends
    by Admin Added 1,203 Views / 1 Likes
    Timber cut ends can quickly soak up water, which rots the wood. By soaking the cut ends in wood preserver you can protect the timber for much longer
  • 15:26 Popular Making a fence panel
    by Admin Added 1,741 Views / 0 Likes
    Making a fence panel can be an enjoyable DIY job, here we make a 6 foot panel from feather edge boards
  • 10:24 Popular How to build a picture frame deck
    by Admin Added 915 Views / 0 Likes
    A picture frame deck can make a decking project look much neater as it creates a frame around the edge of the deck so that no cut ends are visible. In this video a single frame is used but you can use a few frames on a single deck to get the effect that y
  • 04:29 Popular How to fit a door viewer | spy hole
    by Admin Added 1,713 Views / 0 Likes
    This video shows how to quickly install a door viewer (often called a spy hole) into a solid wood door.
  • 04:32 Popular How to make a mitre joint
    by Admin Added 2,436 Views / 0 Likes
  • 14:11 Popular Airing cupboard shelving
    by Admin Added 2,167 Views / 0 Likes
    This video shows how to install shelving and clothes rails into a disused airing cupboard.
  • 04:01 Popular How to use a screw digger
    by Admin Added 2,039 Views / 0 Likes
    How to use a screw digger and plug cutter to conceal screw heads in timber.
  • 06:04 Popular How to fit a letter plate
    by Admin Added 1,046 Views / 0 Likes
    How to fit a letter plate into a wooden door
  • 03:23 Popular How to make a Butt joint
    by Admin Added 1,733 Views / 0 Likes
    This demonstration shows how to make one of the simplest woodworking joints, the butt joint.
  • 07:42 Popular How to make a Feather edge garden gate
    by Admin Added 9,190 Views / 0 Likes
    An inexpensive way to make a garden gate is using some tantalised 4*2 timber and some feather edge boards. You can easily make a garden gate to your required size easily using this method.
  • 01:49 Popular Lubricate wood screws
    by Admin Added 1,928 Views / 0 Likes
    When driving wood screws you can reduce friction and make the screws drive in much faster if you lubricate the screws first
  • 02:16 Popular How to fit internal door handles
    by Admin Added 2,170 Views / 0 Likes
    How to install internal door handles
