Visit Thermo worx
Tool review videos
  • 05:19 Popular Evolution Rage 4 chop saw demonstration
    by Admin Added 646 Views / 0 Likes
    The Evolution Rage 4 is a smaller version of their popular Rage 2 metal cutting chop saw. The Rage 4 is much smaller and is easy to carry virtually anywhere. Once carried to the job site it can be used to cut wood, metal or plastic with the supplied blade
  • 02:41 Popular Trend bar clamp
    Trend bar clamp
    by Admin Added 618 Views / 0 Likes
    The Trend bar clamp and spreader is so easy to use that it can easily be used with just one hand. This clamp is very versatile and by swapping the clamping jaw to the other end of the bar you can use this clamp for spreading, which is extremely useful. Th
  • 05:40 Popular Dewalt tough system cases | DS150 | DS300 |DS400
    by Admin Added 612 Views / 0 Likes
    Dewalt tough system cases are an extremely good way of storing and looking after your valuable tools The Dewalt tough system cases come in several different sizes and additional extras such as a tote tray and tool holders are available. In this video I lo
  • 02:58 Popular Keter folding workbench/table
    by Admin Added 545 Views / 0 Likes
    The Keter folding workbench/table is a light weight and very easy to set up bench. This can quite literally be set up in a matter of seconds. Simply depress two levers with your thumbs and the legs drop from the unit making a sturdy work table/bench that
  • 14:03 Popular Evolution Rage 3DB multipurpose mitre saw review
    by Admin Added 543 Views / 0 Likes
    The Evolution Rage 3DB multipurpose mitre saw can cut wood, aluminium, steel, wood with nails and plastic all with the one blade. Once the machine is fitted with a diamond blade this machine can also cut masonry including steel reinforced concrete such as
  • 05:48 Popular Bosch GOP 250 CE review
    by Admin Added 527 Views / 0 Likes
    Get a multi-tool here- http://fave.co/1JSWziq The Bosch GOP 250 CE Professional is a multi-purpose saw and sander. This machine is ideal for doing jobs that other machines are not capable of, such as flush cutting and plunge cutting small holes. The Bosch
  • 03:11 Popular Evolution mitre saw stand
    by Admin Added 473 Views / 0 Likes
    The Evolution mitre saw stand can be used with any Evolution mitre saw or chop saw, plus other makes of saw which makes this stand very appealing as it is much cheaper than other mitre saw stands on the market today. The stand is very easy to set up and t
  • 02:38 Popular DeWalt DCB090 USB Charger
    by Admin Added 403 Views / 0 Likes
    The DeWalt DCB090-XJ USB Charging XR Battery Adaptor is a useful addition to any toolkit if you already own a 10.8, 14.4 or 18v Dewalt XR battery. By using the DeWalt DCB090 you can power two USB devices, which means you can charge your IPhone, IPad, or u
  • 04:40 Popular Evolution EVO system | Engine, generator, pump and pressure washer
    by Admin Added 365 Views / 0 Likes
    The Evolution EVO system is a brilliant idea allowing you to use the petrol driven engine, either the Evo engine http://fave.co/2lj6IRY or the slightly more expensive Mitsubishi engine (approx. £150 more expensive) to power one of the three outputs.
  • 17:56 Popular Evolution R210SMS | sliding mitre saw review and setup
    by Admin Added 184 Views / 0 Likes
    Evolution tools were kind enough to send out this evolution R210SMS for me to test out and review. This saw is a great piece of kit and I believe is available in January 2018.
  • 05:42 Cobalt step drill bits
    by Admin Added 71 Views / 0 Likes
    Cobalt step drill bits are normally more expensive than normal step drill bits that are normally made from high speed steel, in this video I test out some cobalt step drills that I purchased from bang good. I order the three step drill set as it was the o
  • 07:34 Dewalt DCG412 18V XR cordless grinder
    by Admin Added 70 Views / 0 Likes
    In this video I review the Dewalt DCG412 18V XR cordless grinder which benefits from Steel cut spiral bevel gears, housed in a low profile jam pot gear, the grinder also has an Intelligent trigger and lock off switch a guard that can be easily adjusted wi
  • 06:09 Bergen aviation wrench review
    by Admin Added 62 Views / 0 Likes
    In this short video I show some Bergen aviation spanners or Bergen aviation wrenches which I have been using for a couple of years on site. At about £35 these are a real bargain and can make undoing and tightening nuts and bolts much easier. I bough
  • 03:51 Dewalt DCL050 LED work light
    by Admin Added 60 Views / 0 Likes
    The Dewalt DCL050 LED work light is a great addition to the Dewalt XR range of tools. This work light can run for 10 hours using a 10ah battery on the 500 lumen setting or approximately 20 hours on the 250 lumen setting. I bought my work light from eBay h
