Visit Thermo worx
Tool review videos
  • 05:17 Popular PLS laser level
    PLS laser level
    by Admin Added 1,988 Views / 1 Likes
    PLS laser level, demonstrated by Razor
  • 04:12 Popular Rage 3s mitre saw cutting masonry
    by Admin Added 927 Views / 1 Likes
    Rage diamond blades are available here- In this video I use the Rage 3S sliding mitre was and a Rage diamond blade to cut some common items made from masonry. Being able to cut masonry on a mitre saw has some clear advantages in tha
  • 03:11 Popular Roebuck Uniwrench review
    by Admin Added 914 Views / 1 Likes
    The Roebuck Uniwrench can be used to undo upto 6 different types of fasteners including spline, square, 12 point, 6 point and star. These spanners can be used to remove heads that are up to 70% rounded off, which makes them very useful for the professiona
  • 02:58 Popular Stanley fatmax extreme hammer review
    by Admin Added 903 Views / 1 Likes
    The Stanley Fatmax extreme hammers are available in 14oz and 15oz versions, the 14oz hammer has the same striking force as a 20oz hammer and the 15oz hammer has the same striking force as a 28oz hammer.
  • 01:57 Popular Stanley FatMax Saw Horse review
    by Admin Added 1,540 Views / 1 Likes
    The Stanley FatMax Saw Horse has Adjustable telescopic legs which means you can adjust them up to Maximum height of 1025mm. They are made from tough plastic with Strong Aluminium legs, which can be adjusted to be level on uneven ground. A pair of these sa
  • 03:06 Popular Tacwise 140el review
    by Admin Added 1,113 Views / 0 Likes
    The Tacwise 140el electric stapler/tacker is the ideal solution for repetative stapling or tacking. This machine accepts staples and also brad nails and is a very quick and easy way to fire them into any suitable material.
  • 03:14 Popular Tacwise combi cable tacker review
    by Admin Added 1,219 Views / 1 Likes
    Here the Tacwise combi cable tacker is reviewed in a quick video demonstration showing it’s capabilities on low voltage cable.
  • 02:31 Popular Tacwise Hammer Tacker A11 review
    by Admin Added 708 Views / 0 Likes
    The Tacwise A11hammer tacker is useful for repetitive tacking such as when installing carpet underlay or roofing felt. This is a high quality machine which can fire any of the Tacwise 140 range os staples ranging from 6mm to 10mm in length.
  • 02:01 Popular Tacwise Z1-140 metal stapler
    by Admin Added 1,524 Views / 1 Likes
    A quick video review of the Tacwise z1-140 metal stapler
  • 02:41 Popular Trend bar clamp
    Trend bar clamp
    by Admin Added 628 Views / 0 Likes
    The Trend bar clamp and spreader is so easy to use that it can easily be used with just one hand. This clamp is very versatile and by swapping the clamping jaw to the other end of the bar you can use this clamp for spreading, which is extremely useful. Th
  • 08:40 Popular Vamplier review
    Vamplier review
    by Admin Added 1,366 Views / 1 Likes
    Vampliers are designed to be used for removing screws that cannot be removed using a traditional screwdriver. These pliers are very good at gripping round objects making them very useful when you come across a damaged screw.
  • 02:56 Popular Wera Joker review
    Wera Joker review
    by Admin Added 2,068 Views / 0 Likes
    The Wera Joker is a very well designed spanner that has a ratchet ring spanner at one end and a clever jaw at the open end. The open ended jaw can hole a nut captive, which is something that most spanners cannot do. These are a really handy set of spanner
  • 04:25 Popular Wera Koloss ratchet  review
    by Admin Added 1,104 Views / 0 Likes
    The Wera Koloss is a well made ratchet and hammer combined into one tool, this is a video review of the tool.
  • 03:54 Popular Winbag | inflatable air shim
    by Admin Added 965 Views / 0 Likes
    The winbag is made from a fibre reinforced material making it very tough and durable. It is 2mm thick when deflated meaning it can be pushed into the smallest of gaps. Once inserted it can be inflated up to 50mm (two inches). Deflating the win bag is simp
