Tool review videos
  • 05:40 Popular Dewalt tough system cases | DS150 | DS300 |DS400
    by Admin Added 686 Views / 0 Likes
    Dewalt tough system cases are an extremely good way of storing and looking after your valuable tools The Dewalt tough system cases come in several different sizes and additional extras such as a tote tray and tool holders are available. In this video I lo
  • 03:35 Popular Dewalt 18v cordless framing nailer review.
    by Admin Added 1,353 Views / 0 Likes
    This is the second review of the Dewalt DCN690 cordless 18v framing nailer.
  • 10:36 Popular Evolution rage 3 sliding mitre saw review
    by Admin Added 1,504 Views / 0 Likes
    The Evolution rage3 sliding mitre saw is a welcome addition to any workshop. This machine can cut wood, metal and plastic with the same blade! Not only that but the machine cuts metal with virtually no sparks and no heat!
  • 04:58 Popular Dewalt Air compressor | Dewalt DPC10QTC-GB
    by Admin Added 878 Views / 0 Likes
    The Dewalt DPC10QTC-GB is a small and compact unit that is much quieter than a normal air compressor. The Dewalt DPC10QTC-GB weighs in at just 17kgs and has two quick release connectors which enable two compressed air lines to be connected to the machine
  • 03:51 Popular Dewalt DCL050 LED work light
    by Admin Added 249 Views / 0 Likes
    The Dewalt DCL050 LED work light is a great addition to the Dewalt XR range of tools. This work light can run for 10 hours using a 10ah battery on the 500 lumen setting or approximately 20 hours on the 250 lumen setting. I bought my work light from eBay h
  • 05:48 Popular Bosch GOP 250 CE review
    by Admin Added 568 Views / 0 Likes
    Get a multi-tool here- http://fave.co/1JSWziq The Bosch GOP 250 CE Professional is a multi-purpose saw and sander. This machine is ideal for doing jobs that other machines are not capable of, such as flush cutting and plunge cutting small holes. The Bosch
  • 04:40 Popular Evolution EVO system | Engine, generator, pump and pressure washer
    by Admin Added 459 Views / 0 Likes
    The Evolution EVO system is a brilliant idea allowing you to use the petrol driven engine, either the Evo engine http://fave.co/2lj6IRY or the slightly more expensive Mitsubishi engine (approx. £150 more expensive) to power one of the three outputs.
  • 06:54 Popular Ff hole saw test/review
    by Admin Added 1,444 Views / 0 Likes
    FF holesaw review, This hole saw is a superb piece of kit and far out performs regular hole saws.
  • 05:44 Popular Evolution rage 3b mitre saw review
    by Admin Added 1,148 Views / 0 Likes
    Here is the video review of the evolution rage 3b mitre saw.
  • 03:06 Popular Tacwise 140el review
    by Admin Added 1,168 Views / 0 Likes
    The Tacwise 140el electric stapler/tacker is the ideal solution for repetative stapling or tacking. This machine accepts staples and also brad nails and is a very quick and easy way to fire them into any suitable material.
  • 09:14 Popular Evo saw 355 Review | steel cutting chop saw
    by Admin Added 736 Views / 0 Likes
    This chop saw has been sent to me by Evolution to test out and review. The Evo saw 355 has a 355mm blade (14 inches), this saw can easily cut mild steel and one blade will outlast 20 abrasive discs of the same size which means you can do about 1000 cuts i
  • 03:34 Popular Milwaukee OSD 2 Right angle drill attachment
    by Admin Added 1,769 Views / 0 Likes
    The Milwaukee OSD2 is an attachment that you can use in virtually any regular drill to use it as a right angle drill
  • 02:58 Popular Keter folding workbench/table
    by Admin Added 638 Views / 0 Likes
    The Keter folding workbench/table is a light weight and very easy to set up bench. This can quite literally be set up in a matter of seconds. Simply depress two levers with your thumbs and the legs drop from the unit making a sturdy work table/bench that
  • 17:56 Popular Evolution R210SMS | sliding mitre saw review and setup
    by Admin Added 515 Views / 0 Likes
    Evolution tools were kind enough to send out this evolution R210SMS for me to test out and review. This saw is a great piece of kit and I believe is available in January 2018.
  • 02:56 Popular Wera Joker review
    Wera Joker review
    by Admin Added 2,103 Views / 0 Likes
    The Wera Joker is a very well designed spanner that has a ratchet ring spanner at one end and a clever jaw at the open end. The open ended jaw can hole a nut captive, which is something that most spanners cannot do. These are a really handy set of spanner
  • 04:12 Popular Rage 3s mitre saw cutting masonry
    by Admin Added 986 Views / 1 Likes
    Rage diamond blades are available here- http://fave.co/1Lc2yST In this video I use the Rage 3S sliding mitre was and a Rage diamond blade to cut some common items made from masonry. Being able to cut masonry on a mitre saw has some clear advantages in tha
