Visit Thermo worx
Tool review videos
  • 05:34 Popular Milwaukee 18v impact driver review
    by Admin Added 965 Views / 0 Likes
    Here Rich-Ando reviews the Milwaukee 18v impact driver. These machines are extremely useful and can save considerable time when doing almost any job.
  • 03:54 Popular Winbag | inflatable air shim
    by Admin Added 943 Views / 0 Likes
    The winbag is made from a fibre reinforced material making it very tough and durable. It is 2mm thick when deflated meaning it can be pushed into the smallest of gaps. Once inserted it can be inflated up to 50mm (two inches). Deflating the win bag is simp
  • 04:12 Popular Rage 3s mitre saw cutting masonry
    by Admin Added 912 Views / 1 Likes
    Rage diamond blades are available here- http://fave.co/1Lc2yST In this video I use the Rage 3S sliding mitre was and a Rage diamond blade to cut some common items made from masonry. Being able to cut masonry on a mitre saw has some clear advantages in tha
  • 03:11 Popular Roebuck Uniwrench review
    by Admin Added 907 Views / 1 Likes
    The Roebuck Uniwrench can be used to undo upto 6 different types of fasteners including spline, square, 12 point, 6 point and star. These spanners can be used to remove heads that are up to 70% rounded off, which makes them very useful for the professiona
  • 02:58 Popular Stanley fatmax extreme hammer review
    by Admin Added 893 Views / 1 Likes
    The Stanley Fatmax extreme hammers are available in 14oz and 15oz versions, the 14oz hammer has the same striking force as a 20oz hammer and the 15oz hammer has the same striking force as a 28oz hammer.
  • 16:28 Popular Milwaukee M18 Fuel Combi Drill & Impact Wrench Twin Pack
    by Admin Added 857 Views / 0 Likes
    Here Razor reviews the Milwaukee M18 fuel twinpack comprising of the Milwaukee 18v Cordless drill and impact wrench
  • 03:54 Popular Bahco reversible ratchet spanner review
    by Admin Added 837 Views / 0 Likes
    The Bahco reversible ratchet spanners are extremely good quality and are very useful. Because one spanner has 4 different sized ratchet rings it makes them very easy to use as you are always guaranteed to have the right size spanner for the job. Finish fo
  • 03:54 Popular Magic Gripper review
    by Admin Added 826 Views / 1 Likes
    Magic grippers are a geat way to hold awkward work pieces such as doors
  • 26:43 Popular Evolution Rage 5-S table saw review
    by Admin Added 816 Views / 1 Likes
    This Rage 5-S table saw was kindly sent to me by Evolution power tools for me to be able to complete some projects, so here is the review of it. I did have the Evolution Fury 5 before this table saw but it often got in my way (despite installing wheels on
  • 07:41 Popular Milwaukee 18v Impact wrench Review
    by Admin Added 770 Views / 0 Likes
    This is a review of the Milwaukee 18v Impact wrench
  • 04:58 Popular Dewalt Air compressor | Dewalt DPC10QTC-GB
    by Admin Added 744 Views / 0 Likes
    The Dewalt DPC10QTC-GB is a small and compact unit that is much quieter than a normal air compressor. The Dewalt DPC10QTC-GB weighs in at just 17kgs and has two quick release connectors which enable two compressed air lines to be connected to the machine
  • 13:12 Popular Dewalt DWS780 | 12 inch double bevel sliding mitre saw
    by Admin Added 732 Views / 0 Likes
    The Dewalt DWS780 is a 12 inch double bevel sliding mitre saw, the blade is 305mm or 12 inches. This sliding mitre saw has a 1675w motor and is powerful enough to cut the hardest timber. This mitre saw uses XPS technology to illuminate the blade, which cr
  • 09:19 Popular Evolution R210CMS metal cutting compound mitre saw
    by Admin Added 721 Views / 0 Likes
    The Evolution R210CMS is a compound mitre saw that can cut wood, steel or plastic all with the supplied blade. Costing less than £50 this machine is superb for the home DIY user that does not need one of the larger Evolution machines. The machine is
  • 02:43 Popular Dewalt 18v XR to XRP battery convertor | Dewalt DCA1820
    by Admin Added 703 Views / 0 Likes
    The Dewalt DCA1820 enables new Dewalt XR batteries to be used with older Dewalt XRP machines, this means that you do not need to replace your older Dewalt power tools and can use newer technology batteries on the older machines. Some newer Dewalt batterie
  • 02:31 Popular Tacwise Hammer Tacker A11 review
    by Admin Added 702 Views / 0 Likes
    The Tacwise A11hammer tacker is useful for repetitive tacking such as when installing carpet underlay or roofing felt. This is a high quality machine which can fire any of the Tacwise 140 range os staples ranging from 6mm to 10mm in length.
  • 09:14 Popular Evo saw 355 Review | steel cutting chop saw
    by Admin Added 658 Views / 0 Likes
    This chop saw has been sent to me by Evolution to test out and review. The Evo saw 355 has a 355mm blade (14 inches), this saw can easily cut mild steel and one blade will outlast 20 abrasive discs of the same size which means you can do about 1000 cuts i
