Tool review videos
  • 02:42 Popular KNIPEX CoBolt Compact Bolt Cutters
    by Admin Added 5,819 Views / 0 Likes
    KNIPEX CoBolt® Compact Bolt Cutters will easily cut through materials that other cutting pliers will not touch. These cutters will make light work of cutting most materials as the cutting force is more than 20 times greater than the force applied . Th
  • 03:54 Popular Magic Gripper review
    by Admin Added 852 Views / 1 Likes
    Magic grippers are a geat way to hold awkward work pieces such as doors
  • 06:50 Popular Makita SK102 cross line laser level review
    by Admin Added 2,532 Views / 1 Likes
    Here the Makita SK102 cross line laser level is reviewed and demonstrated.
  • 04:39 Popular Milwaukee 12v Hackzall review
    by Admin Added 1,417 Views / 1 Likes
    The Milwaukee Hacksall is available on the M12 platform, which means it will work with any of the Milwaukee 12v Lithium ion batteries. This machine is small and compact, here we test it out cutting some timber and some steel bar. Brought to you by http://
  • 05:50 Popular Milwaukee 12v impact driver review
    by Admin Added 1,243 Views / 1 Likes
    Here the Milwaukee 12v impact driver is reviewed to see just how good the machine is and what features the machine has.
  • 05:34 Popular Milwaukee 18v impact driver review
    by Admin Added 1,012 Views / 0 Likes
    Here Rich-Ando reviews the Milwaukee 18v impact driver. These machines are extremely useful and can save considerable time when doing almost any job.
  • 07:41 Popular Milwaukee 18v Impact wrench Review
    by Admin Added 827 Views / 0 Likes
    This is a review of the Milwaukee 18v Impact wrench
  • 03:58 Popular Milwaukee C12D review
    by Admin Added 1,462 Views / 0 Likes
    The Milwaukee C12D is a 12v Li-ion drill driver. This drill is one of the smallest and lightest drills you will ever see and uses a ¼ inch hex shank chuck to hold the bits. This machine is very easy to use and is much easier to use than a standard
  • 01:26 Popular Milwaukee fastback review
    by Admin Added 1,164 Views / 0 Likes
    The Fastback from Milwaukee is a very well designed knife that is very good to handle and safe to use. The Fastback is made completely from metal, so there are no plastic parts on the knife at all. Replacing the blade on the Milwaukee Fastback is very sim
  • 07:03 Popular Milwaukee FUEL 18v impact wrench review
    by Admin Added 1,057 Views / 1 Likes
    The Milwaukee 2763-20 M18v FUEL is reviewed in this video. The Milwaukee 2763-20 M18v FUEL is probably the most powerful 18v impact wrench available today and has a staggering 1100 foot pounds of undoing torque. This machine will undo most fasteners even
  • 05:02 Popular Milwaukee HD18 HIW 18v impact wrench torque test
    by Admin Added 1,868 Views / 1 Likes
    Milwaukee HD18 HIW Torque test
  • 03:30 Popular Milwaukee M12 IR ratchet review
    by Admin Added 2,275 Views / 1 Likes
    Milwaukee's M12 IR is a 12v cordless ratchet that is available in ¼ inch or 3/8 inch drive, this compact ratchet can get into most tight places and can really save time on most jobs.
  • 16:28 Popular Milwaukee M18 Fuel Combi Drill & Impact Wrench Twin Pack
    by Admin Added 935 Views / 0 Likes
    Here Razor reviews the Milwaukee M18 fuel twinpack comprising of the Milwaukee 18v Cordless drill and impact wrench
  • 03:34 Popular Milwaukee OSD 2 Right angle drill attachment
    by Admin Added 1,789 Views / 0 Likes
    The Milwaukee OSD2 is an attachment that you can use in virtually any regular drill to use it as a right angle drill
  • 06:46 Popular Mirka Deros review
    Mirka Deros review
    by Admin Added 1,144 Views / 1 Likes
    The Mirka Deros is much better at sanding than traditional sanding machines. This machine is much quitter and easier to use than most other orbital sanders. The Mirka Deros can also be used with either the 125mm pad or the 150mm backing pad making this ma
  • 02:47 Popular Never buy cheap tools
    by Admin Added 2,181 Views / 2 Likes
    Cheap tools are often false economy and can make your job ten times harder. Buy cheap buy twice is a motto that is very true
