Tool review videos
  • 05:42 Popular Cobalt step drill bits
    by Admin Added 265 Views / 0 Likes
    Cobalt step drill bits are normally more expensive than normal step drill bits that are normally made from high speed steel, in this video I test out some cobalt step drills that I purchased from bang good. I order the three step drill set as it was the o
  • 04:25 Popular Wera Koloss ratchet  review
    by Admin Added 1,156 Views / 0 Likes
    The Wera Koloss is a well made ratchet and hammer combined into one tool, this is a video review of the tool.
  • 02:43 Popular Dewalt 18v XR to XRP battery convertor | Dewalt DCA1820
    by Admin Added 883 Views / 0 Likes
    The Dewalt DCA1820 enables new Dewalt XR batteries to be used with older Dewalt XRP machines, this means that you do not need to replace your older Dewalt power tools and can use newer technology batteries on the older machines. Some newer Dewalt batterie
  • 07:05 Popular Bosch PMF 180E review
    by Admin Added 1,998 Views / 0 Likes
  • 02:42 Popular KNIPEX CoBolt Compact Bolt Cutters
    by Admin Added 5,819 Views / 0 Likes
    KNIPEX CoBolt® Compact Bolt Cutters will easily cut through materials that other cutting pliers will not touch. These cutters will make light work of cutting most materials as the cutting force is more than 20 times greater than the force applied . Th
  • 02:41 Popular Trend bar clamp
    Trend bar clamp
    by Admin Added 657 Views / 0 Likes
    The Trend bar clamp and spreader is so easy to use that it can easily be used with just one hand. This clamp is very versatile and by swapping the clamping jaw to the other end of the bar you can use this clamp for spreading, which is extremely useful. Th
  • 03:54 Popular Winbag | inflatable air shim
    by Admin Added 1,027 Views / 0 Likes
    The winbag is made from a fibre reinforced material making it very tough and durable. It is 2mm thick when deflated meaning it can be pushed into the smallest of gaps. Once inserted it can be inflated up to 50mm (two inches). Deflating the win bag is simp
  • 03:56 Nilfisk patio cleaner
    by Admin Added 36 Views / 0 Likes
    The Nilfisk patio cleaner is the ideal solution for cleaning large areas such as decks, patio’s, driveways or walls. The brush seal prevents the water from being directed where you do not want it and the rotating head makes light work of cleaning la
  • 07:41 Popular Milwaukee 18v Impact wrench Review
    by Admin Added 827 Views / 0 Likes
    This is a review of the Milwaukee 18v Impact wrench
  • 03:54 Popular Bahco reversible ratchet spanner review
    The Bahco reversible ratchet spanners are extremely good quality and are very useful. Because one spanner has 4 different sized ratchet rings it makes them very easy to use as you are always guaranteed to have the right size spanner for the job. Finish fo
  • 02:31 Popular Tacwise Hammer Tacker A11 review
    by Admin Added 748 Views / 0 Likes
    The Tacwise A11hammer tacker is useful for repetitive tacking such as when installing carpet underlay or roofing felt. This is a high quality machine which can fire any of the Tacwise 140 range os staples ranging from 6mm to 10mm in length.
  • 14:03 Popular Evolution Rage 3DB multipurpose mitre saw review
    by Admin Added 655 Views / 0 Likes
    The Evolution Rage 3DB multipurpose mitre saw can cut wood, aluminium, steel, wood with nails and plastic all with the one blade. Once the machine is fitted with a diamond blade this machine can also cut masonry including steel reinforced concrete such as
  • 07:34 Popular Dewalt DCG412 18V XR cordless grinder
    by Admin Added 301 Views / 0 Likes
    In this video I review the Dewalt DCG412 18V XR cordless grinder which benefits from Steel cut spiral bevel gears, housed in a low profile jam pot gear, the grinder also has an Intelligent trigger and lock off switch a guard that can be easily adjusted wi
  • 06:35 Popular Dewalt 18v grinder review
    by Admin Added 1,552 Views / 0 Likes
    Dewalt 18v cordless Grinder review.
  • 04:00 Popular Halfords professional ratchet spanner review
    The Halfords professional ratchet spanners are reviewed in this video. This set of spanners includes all sizes from 19mm to 8mm and is a very useful set of spanners to own. These are currently on sale for £39.99 but normally retail for £79.99
  • 09:19 Popular Evolution R210CMS metal cutting compound mitre saw
    by Admin Added 843 Views / 0 Likes
    The Evolution R210CMS is a compound mitre saw that can cut wood, steel or plastic all with the supplied blade. Costing less than £50 this machine is superb for the home DIY user that does not need one of the larger Evolution machines. The machine is
