Tool review videos
  • 02:01 Popular Tacwise Z1-140 metal stapler
    by Admin Added 1,610 Views / 1 Likes
    A quick video review of the Tacwise z1-140 metal stapler
  • 01:57 Popular Stanley FatMax Saw Horse review
    by Admin Added 1,591 Views / 1 Likes
    The Stanley FatMax Saw Horse has Adjustable telescopic legs which means you can adjust them up to Maximum height of 1025mm. They are made from tough plastic with Strong Aluminium legs, which can be adjusted to be level on uneven ground. A pair of these sa
  • 01:21 Popular Bahco 808050L ratchet screwdriver review
    by Admin Added 1,557 Views / 2 Likes
    The Bahco 808050L ratchet screwdriver Is a very handy screwdriver to have around the house, the integrated LED light makes working in dark conditions much easier. The screwdriver has a ratchet function and use a ¼ inch hex bit holder to hold the sc
  • 06:35 Popular Dewalt 18v grinder review
    by Admin Added 1,546 Views / 0 Likes
    Dewalt 18v cordless Grinder review.
  • 10:36 Popular Evolution rage 3 sliding mitre saw review
    by Admin Added 1,516 Views / 0 Likes
    The Evolution rage3 sliding mitre saw is a welcome addition to any workshop. This machine can cut wood, metal and plastic with the same blade! Not only that but the machine cuts metal with virtually no sparks and no heat!
  • 02:54 Popular Grip tite socket review
    by Admin Added 1,499 Views / 1 Likes
    Grip tite sockets can be used to remove nuts and bolts that have become rounded off. These sockets are also useful at holding the nut or bolt captive intil it is in position.
  • 03:40 Popular Dewalt DW999 Cordless SDS 18V review
    by Admin Added 1,493 Views / 0 Likes
    This video shows how versatile the Dewalt DW999 Cordless SDS 18 V drill is.
  • 02:59 Popular Bosch PMF 10.8 Li
    Bosch PMF 10.8 Li
    by Admin Added 1,485 Views / 1 Likes
    Bosch PMF 10.8 Li cutting a steel drain cover. These machines are very versatile and can be extremely useful.
  • 03:58 Popular Milwaukee C12D review
    by Admin Added 1,460 Views / 0 Likes
    The Milwaukee C12D is a 12v Li-ion drill driver. This drill is one of the smallest and lightest drills you will ever see and uses a ¼ inch hex shank chuck to hold the bits. This machine is very easy to use and is much easier to use than a standard
    by Admin Added 1,457 Views / 1 Likes
  • 06:54 Popular Ff hole saw test/review
    by Admin Added 1,450 Views / 0 Likes
    FF holesaw review, This hole saw is a superb piece of kit and far out performs regular hole saws.
  • 07:08 Popular Bosch multi construction drill bit
    by Admin Added 1,447 Views / 1 Likes
    Bosch multi construction drill bit are tested, these drills can be used on wood, metal, masonry and tiles.
  • 04:39 Popular Milwaukee 12v Hackzall review
    by Admin Added 1,416 Views / 1 Likes
    The Milwaukee Hacksall is available on the M12 platform, which means it will work with any of the Milwaukee 12v Lithium ion batteries. This machine is small and compact, here we test it out cutting some timber and some steel bar. Brought to you by http://
  • 08:40 Popular Vamplier review
    Vamplier review
    by Admin Added 1,409 Views / 1 Likes
    Vampliers are designed to be used for removing screws that cannot be removed using a traditional screwdriver. These pliers are very good at gripping round objects making them very useful when you come across a damaged screw.
  • 03:35 Popular Dewalt 18v cordless framing nailer review.
    by Admin Added 1,366 Views / 0 Likes
    This is the second review of the Dewalt DCN690 cordless 18v framing nailer.
  • 03:02 Popular Open ended ratchet spanner | Chicago brand
    by Admin Added 1,359 Views / 1 Likes
    Ratchet spanners are now increasingly popular and are now sold under many brands. The Chicago Brand open ended ratchet spanner is a quality spanner which is made from high grade stainless steel. These spanners are used widely in the aircraft industry.
