Visit Thermo worx
Tool review videos
    by Admin Added 1,328 Views / 1 Likes
  • 02:38 Popular DeWalt DCB090 USB Charger
    by Admin Added 392 Views / 0 Likes
    The DeWalt DCB090-XJ USB Charging XR Battery Adaptor is a useful addition to any toolkit if you already own a 10.8, 14.4 or 18v Dewalt XR battery. By using the DeWalt DCB090 you can power two USB devices, which means you can charge your IPhone, IPad, or u
  • 07:15 Popular DEWALT DCF887 18V XR BRUSHLESS IMPACT DRIVER
    by Admin Added 1,066 Views / 0 Likes
    The DEWALT DCF887 18V XR BRUSHLESS IMPACT DRIVER is an awesome impact driver for driving in most screws. In this review I drive in some large screws that would be impossible for most other impact drivers. This machine has a maximum torque of 205NM and can
  • 07:34 Dewalt DCG412 18V XR cordless grinder
    by Admin Added 39 Views / 0 Likes
    In this video I review the Dewalt DCG412 18V XR cordless grinder which benefits from Steel cut spiral bevel gears, housed in a low profile jam pot gear, the grinder also has an Intelligent trigger and lock off switch a guard that can be easily adjusted wi
  • 03:51 Dewalt DCL050 LED work light
    by Admin Added 29 Views / 0 Likes
    The Dewalt DCL050 LED work light is a great addition to the Dewalt XR range of tools. This work light can run for 10 hours using a 10ah battery on the 500 lumen setting or approximately 20 hours on the 250 lumen setting. I bought my work light from eBay h
  • 05:20 Popular Dewalt DCN690 cordless framing nailer
    by Admin Added 1,047 Views / 0 Likes
    The Dewalt DCN690 is a revolutionary cordless nail gun that requires no gas
  • 03:40 Popular Dewalt DW999 Cordless SDS 18V review
    by Admin Added 1,397 Views / 0 Likes
    This video shows how versatile the Dewalt DW999 Cordless SDS 18 V drill is.
  • 13:12 Popular Dewalt DWS780 | 12 inch double bevel sliding mitre saw
    by Admin Added 711 Views / 0 Likes
    The Dewalt DWS780 is a 12 inch double bevel sliding mitre saw, the blade is 305mm or 12 inches. This sliding mitre saw has a 1675w motor and is powerful enough to cut the hardest timber. This mitre saw uses XPS technology to illuminate the blade, which cr
  • 08:31 Popular Dewalt Li-Ion battery versus Ni-Cad
    by Admin Added 1,155 Views / 1 Likes
    Here wetest out the latest Li-Ion battery from Dewalt. These batteries can be charged 2000 times and have no "memory effect".
  • 05:40 Popular Dewalt tough system cases | DS150 | DS300 |DS400
    by Admin Added 599 Views / 0 Likes
    Dewalt tough system cases are an extremely good way of storing and looking after your valuable tools The Dewalt tough system cases come in several different sizes and additional extras such as a tote tray and tool holders are available. In this video I lo
  • 02:29 Popular Dewalt Universal Mitre Saw Stand | Dewalt DE7023
    by Admin Added 1,814 Views / 1 Likes
    The Dewalt DE7023 Leg Stand/Universal Mitre Saw Stand is one of the most useful stands available today. It can safely hold weights up to 225KG and if used in conjunction with the DE7025 brackets it is possible to use the stand to hold a variety of differe
  • 09:14 Popular Evo saw 355 Review | steel cutting chop saw
    by Admin Added 633 Views / 0 Likes
    This chop saw has been sent to me by Evolution to test out and review. The Evo saw 355 has a 355mm blade (14 inches), this saw can easily cut mild steel and one blade will outlast 20 abrasive discs of the same size which means you can do about 1000 cuts i
  • 04:40 Popular Evolution EVO system | Engine, generator, pump and pressure washer
    by Admin Added 342 Views / 0 Likes
    The Evolution EVO system is a brilliant idea allowing you to use the petrol driven engine, either the Evo engine http://fave.co/2lj6IRY or the slightly more expensive Mitsubishi engine (approx. £150 more expensive) to power one of the three outputs.
  • 09:08 Popular Evolution Fury 5-S table saw review
    by Admin Added 2,122 Views / 0 Likes
    The Evolution Fury 5 S table saw is a table saw that can cut wood, metal or plastic all with the same blade. This machine has a 10 inch blade or 255mm which enables it to cut material up to 70mm deep. You can easily cut aluminium or steel with the same bl
  • 02:59 Popular Evolution mini belt sander
    by Admin Added 1,086 Views / 1 Likes
    Here the Evolution mini belt sander is tested out. This handy little machine can tackle the toughest of jobs although the dust collection bag can be difficult to fix in position. This machine takes 40mm by 305mm long belts and these are widely available i
  • 03:11 Popular Evolution mitre saw stand
    by Admin Added 454 Views / 0 Likes
    The Evolution mitre saw stand can be used with any Evolution mitre saw or chop saw, plus other makes of saw which makes this stand very appealing as it is much cheaper than other mitre saw stands on the market today. The stand is very easy to set up and t
