Tool review videos
  • 03:11 Popular Roebuck Uniwrench review
    by Admin Added 946 Views / 1 Likes
    The Roebuck Uniwrench can be used to undo upto 6 different types of fasteners including spline, square, 12 point, 6 point and star. These spanners can be used to remove heads that are up to 70% rounded off, which makes them very useful for the professiona
  • 08:40 Popular Vamplier review
    Vamplier review
    by Admin Added 1,409 Views / 1 Likes
    Vampliers are designed to be used for removing screws that cannot be removed using a traditional screwdriver. These pliers are very good at gripping round objects making them very useful when you come across a damaged screw.
  • 06:50 Popular Makita SK102 cross line laser level review
    by Admin Added 2,530 Views / 1 Likes
    Here the Makita SK102 cross line laser level is reviewed and demonstrated.
  • 06:46 Popular Mirka Deros review
    Mirka Deros review
    by Admin Added 1,140 Views / 1 Likes
    The Mirka Deros is much better at sanding than traditional sanding machines. This machine is much quitter and easier to use than most other orbital sanders. The Mirka Deros can also be used with either the 125mm pad or the 150mm backing pad making this ma
  • 07:07 Popular Dewalt 18v reciprocating saw review | Dewalt DW 938
    by Admin Added 1,808 Views / 1 Likes
    Here is the video review of the extremely handy Dewalt 18v reciprocating saw (DW 938), this has now been replaced be a newer model.
  • 03:30 Popular Milwaukee M12 IR ratchet review
    by Admin Added 2,272 Views / 1 Likes
    Milwaukee's M12 IR is a 12v cordless ratchet that is available in ¼ inch or 3/8 inch drive, this compact ratchet can get into most tight places and can really save time on most jobs.
  • 02:59 Popular Bosch PMF 10.8 Li
    Bosch PMF 10.8 Li
    by Admin Added 1,485 Views / 1 Likes
    Bosch PMF 10.8 Li cutting a steel drain cover. These machines are very versatile and can be extremely useful.
  • 05:02 Popular Milwaukee HD18 HIW 18v impact wrench torque test
    by Admin Added 1,868 Views / 1 Likes
    Milwaukee HD18 HIW Torque test
  • 03:53 Popular BETA C41 tool trolley review
    by Admin Added 1,650 Views / 1 Likes
    The BETA C41H 2 DRAWER, two module toolbox/chest is a good solution when you need to move a large amount of tools to the job.
  • 03:02 Popular Open ended ratchet spanner | Chicago brand
    by Admin Added 1,359 Views / 1 Likes
    Ratchet spanners are now increasingly popular and are now sold under many brands. The Chicago Brand open ended ratchet spanner is a quality spanner which is made from high grade stainless steel. These spanners are used widely in the aircraft industry.
  • 05:50 Popular Milwaukee 12v impact driver review
    by Admin Added 1,243 Views / 1 Likes
    Here the Milwaukee 12v impact driver is reviewed to see just how good the machine is and what features the machine has.
  • 03:45 Popular Evolution Rage 1b circular saw review
    by Admin Added 1,079 Views / 1 Likes
    The Evolution Rage 1b circular saw is a very handy piece of kit because it can cut metal, wood and plastic all with the same blade. You will see me using this in many videos as it is light weight and easy to use.
  • 03:54 Popular Magic Gripper review
    by Admin Added 852 Views / 1 Likes
    Magic grippers are a geat way to hold awkward work pieces such as doors
  • 07:03 Popular Milwaukee FUEL 18v impact wrench review
    by Admin Added 1,053 Views / 1 Likes
    The Milwaukee 2763-20 M18v FUEL is reviewed in this video. The Milwaukee 2763-20 M18v FUEL is probably the most powerful 18v impact wrench available today and has a staggering 1100 foot pounds of undoing torque. This machine will undo most fasteners even
  • 26:43 Popular Evolution Rage 5-S table saw review
    by Admin Added 1,228 Views / 1 Likes
    This Rage 5-S table saw was kindly sent to me by Evolution power tools for me to be able to complete some projects, so here is the review of it. I did have the Evolution Fury 5 before this table saw but it often got in my way (despite installing wheels on
  • 07:08 Popular Bosch multi construction drill bit
    by Admin Added 1,447 Views / 1 Likes
    Bosch multi construction drill bit are tested, these drills can be used on wood, metal, masonry and tiles.
