Tool review videos
  • 07:15 Popular bosch dmf 10 digital detector review
    by Admin Added 7,800 Views / 11 Likes
    Bosch dmf 10 digital detector review
  • 08:09 Popular Dewalt 18v Cordless circular saw | Dewalt DW 936
    by Admin Added 2,424 Views / 3 Likes
    Dewalt DW 936 review
  • 02:47 Popular Never buy cheap tools
    by Admin Added 2,230 Views / 2 Likes
    Cheap tools are often false economy and can make your job ten times harder. Buy cheap buy twice is a motto that is very true
  • 01:21 Popular Bahco 808050L ratchet screwdriver review
    by Admin Added 1,632 Views / 2 Likes
    The Bahco 808050L ratchet screwdriver Is a very handy screwdriver to have around the house, the integrated LED light makes working in dark conditions much easier. The screwdriver has a ratchet function and use a ¼ inch hex bit holder to hold the sc
  • 05:17 Popular PLS laser level
    PLS laser level
    by Admin Added 2,071 Views / 1 Likes
    PLS laser level, demonstrated by Razor
  • 02:54 Popular Grip tite socket review
    by Admin Added 1,578 Views / 1 Likes
    Grip tite sockets can be used to remove nuts and bolts that have become rounded off. These sockets are also useful at holding the nut or bolt captive intil it is in position.
  • 08:31 Popular Dewalt Li-Ion battery versus Ni-Cad
    by Admin Added 1,347 Views / 1 Likes
    Here wetest out the latest Li-Ion battery from Dewalt. These batteries can be charged 2000 times and have no "memory effect".
  • 03:11 Popular Roebuck Uniwrench review
    by Admin Added 1,006 Views / 1 Likes
    The Roebuck Uniwrench can be used to undo upto 6 different types of fasteners including spline, square, 12 point, 6 point and star. These spanners can be used to remove heads that are up to 70% rounded off, which makes them very useful for the professiona
  • 08:40 Popular Vamplier review
    Vamplier review
    by Admin Added 1,499 Views / 1 Likes
    Vampliers are designed to be used for removing screws that cannot be removed using a traditional screwdriver. These pliers are very good at gripping round objects making them very useful when you come across a damaged screw.
  • 06:50 Popular Makita SK102 cross line laser level review
    by Admin Added 2,604 Views / 1 Likes
    Here the Makita SK102 cross line laser level is reviewed and demonstrated.
  • 06:46 Popular Mirka Deros review
    Mirka Deros review
    by Admin Added 1,386 Views / 1 Likes
    The Mirka Deros is much better at sanding than traditional sanding machines. This machine is much quitter and easier to use than most other orbital sanders. The Mirka Deros can also be used with either the 125mm pad or the 150mm backing pad making this ma
  • 07:07 Popular Dewalt 18v reciprocating saw review | Dewalt DW 938
    by Admin Added 1,950 Views / 1 Likes
    Here is the video review of the extremely handy Dewalt 18v reciprocating saw (DW 938), this has now been replaced be a newer model.
  • 03:30 Popular Milwaukee M12 IR ratchet review
    by Admin Added 2,359 Views / 1 Likes
    Milwaukee's M12 IR is a 12v cordless ratchet that is available in ¼ inch or 3/8 inch drive, this compact ratchet can get into most tight places and can really save time on most jobs.
  • 02:59 Popular Bosch PMF 10.8 Li
    Bosch PMF 10.8 Li
    by Admin Added 1,564 Views / 1 Likes
    Bosch PMF 10.8 Li cutting a steel drain cover. These machines are very versatile and can be extremely useful.
  • 05:02 Popular Milwaukee HD18 HIW 18v impact wrench torque test
    by Admin Added 1,959 Views / 1 Likes
    Milwaukee HD18 HIW Torque test
  • 03:53 Popular BETA C41 tool trolley review
    by Admin Added 1,744 Views / 1 Likes
    The BETA C41H 2 DRAWER, two module toolbox/chest is a good solution when you need to move a large amount of tools to the job.
