Toilet videos
Toilet removal, installation and repair videos
Toilets are normally pretty reliable, but occasionally they do require fixing. This section has videos showing how to replace most parts within the toilet. You can also learn how to remove and install a new toilet by watching the videos in this section.
  • 22:59 Popular replacing a close coupled toilet syphon
    by Admin Added 3,917 Views / 2 Likes
    How to replace the syphon in a close coupled toilet
  • 14:18 Popular How to install a back to wall toilet
    by Admin Added 3,090 Views / 3 Likes
    How to install a back to wall toilet and concealed cistern.
  • 08:16 Popular Installing a toilet water inlet valve
    by Admin Added 3,024 Views / 2 Likes
    How to replace a compact water inlet valve in a toilet cistern .
  • 02:35 Popular How to remove a toilet pan
    by Admin Added 2,844 Views / 0 Likes
    Removing the toilet pan is necessary so that the floor can be over boarded and tiled, here we show how to remove the pan.
  • 02:37 Popular How to remove a toilet cistern
    by Admin Added 2,679 Views / 0 Likes
    To remove the tiles from the back of the toilet you often need to remove the cistern. The toilet pan can be left in position which means that you can still flush the toilet by using a bucket of water if necessary.
  • 00:39 Popular Flushing a broken toilet
    by Admin Added 2,096 Views / 0 Likes
    How to flush a toilet when the flushing mechanism is broken
  • 02:16 Popular replace a broken toilet lever
    by Admin Added 2,089 Views / 0 Likes
    Toilet levers occassionally snap as they are only made from zinc.
  • 03:38 Popular How to adjust or fit a toilet seat
    by Admin Added 1,624 Views / 0 Likes
    It's a common problem for toilet seats to drop down when they are lifted into the up position.
