Tiling videos
Tiling any surface can be difficult without the correct preparation and tools.
This section contains videos showing how to cut and fix most tiles easily and also shows which tools are best for fixing the tiles. Once you know how to cut and fix the tiles correctly the job becomes much easier.
  • 06:55 Popular Installing tile trim on a out of level wall
    by Admin Added 3,274 Views / 0 Likes
    Here a tile trim is fitted to a wall that is not straight, this can be difficult to overcome and so a workaround solution is demonstrated.
  • 14:32 Popular Tanking a shower area
    by Admin Added 2,783 Views / 1 Likes
    Tanking a shower area is always a good idea as water eventually gets behind tiles causing the plasterboard to perish.
  • 03:12 Popular Tile cutting using a grinder
    by Admin Added 1,647 Views / 0 Likes
    Angle grinders when used with a diamond tipped disc can be used to cut virtually any type of tile, in this demonstration I cut a curve in a ceramic tile. This method works well on all natural stone tiles such as Marble and Slate but can alsobe used on por
  • 01:15 Popular Tile file
    Tile file
    by Admin Added 1,416 Views / 0 Likes
    A tile file is useful to remove sharp edges from a cut tile
  • 06:35 Popular Tile grouting
    Tile grouting
    by Admin Added 2,143 Views / 0 Likes
    How to grout tiles
  • 02:39 Popular Tile nibblers
    Tile nibblers
    by Admin Added 1,309 Views / 0 Likes
    Tile nibblers are useful for removing small pieces of tile
  • 04:47 Popular Tiling around pipe entries
    by Admin Added 3,619 Views / 1 Likes
    How to tile around pipe entries, this is useful if you are fitting a wall mounted tap etc.
  • 09:57 Popular where to start tiling
    by Admin Added 3,446 Views / 1 Likes
    This video shows how to determine the best place to start tiling a wall. It is important that the correct starting position is determined as you need to avoid getting in a situation where you need to cut thin slivers of tiles as it is almost impossible to
