Tiling videos
Tiling any surface can be difficult without the correct preparation and tools.
This section contains videos showing how to cut and fix most tiles easily and also shows which tools are best for fixing the tiles. Once you know how to cut and fix the tiles correctly the job becomes much easier.
  • 12:11 Popular Floor tiling
    Floor tiling
    by Admin Added 4,528 Views / 2 Likes
    This video shows how to tile a floor using rapid setting adhesive.
  • 19:55 Popular How to tile a bathroom
    by Admin Added 4,176 Views / 1 Likes
    This video shows how to tile a wall and make the all important scribe cuts. Wall tiling is often difficult and can be time consuming. Hopefully this video will help people when they are wall tiling.
  • 04:47 Popular Tiling around pipe entries
    by Admin Added 3,686 Views / 1 Likes
    How to tile around pipe entries, this is useful if you are fitting a wall mounted tap etc.
  • 09:57 Popular where to start tiling
    by Admin Added 3,501 Views / 1 Likes
    This video shows how to determine the best place to start tiling a wall. It is important that the correct starting position is determined as you need to avoid getting in a situation where you need to cut thin slivers of tiles as it is almost impossible to
  • 06:55 Popular Installing tile trim on a out of level wall
    by Admin Added 3,363 Views / 0 Likes
    Here a tile trim is fitted to a wall that is not straight, this can be difficult to overcome and so a workaround solution is demonstrated.
  • 05:32 Popular How to grout floor tiles
    by Admin Added 2,878 Views / 0 Likes
    Grouting floor tiles can be tricky and needs doing before you walk on the floor times if possible. This video shows how to mix the grout and then apply the grout to the gaps in the tiles.
  • 14:32 Popular Tanking a shower area
    by Admin Added 2,835 Views / 1 Likes
    Tanking a shower area is always a good idea as water eventually gets behind tiles causing the plasterboard to perish.
  • 04:11 Popular How to remove tiles
    How to remove tiles
    by Admin Added 2,703 Views / 1 Likes
    Removing tiles can be tricky, it is best to take a methodical approach rather than going at it like a bull in a china shop. Here we remove wall tiles using a knock through screwdriver and hammer.
  • 06:35 Popular Tile grouting
    Tile grouting
    by Admin Added 2,187 Views / 0 Likes
    How to grout tiles
  • 10:38 Popular How to tile a kitchen backsplash part 1
    by Admin Added 2,033 Views / 2 Likes
    How to tile a kitchen backsplash part 1 Part 2 can be seen here- http://www.ultimatehandyman.co.uk/video/how-to-tile-a-kitchen-backsplash-part-2-video_2755f789e.html
  • 02:13 Popular Difficult tile cutting
    by Admin Added 1,916 Views / 0 Likes
    How to cut an awkward square shape from a tile using two different types of tile cutter
  • 03:45 Popular How to cut tiles with a standard tile cutter
    by Admin Added 1,887 Views / 1 Likes
    How to cut tiles using a standard tile cutter.
  • 02:42 Popular How to cut a curved tile using a traditional tile cutter
    by Admin Added 1,815 Views / 0 Likes
    Cutting a curved tile may be necessary if you ever need to tile up to a shower encolsure. This video shows how to cut the tile on a traditional tile cutting machine.
  • 04:00 Popular How to drill porcelain tiles
    by Admin Added 1,814 Views / 0 Likes
    Porcelain tiles are tough and difficult to drill. Here we show how to drill them
  • 02:19 Popular How to cut a square hole in a tile
    by Admin Added 1,753 Views / 0 Likes
    How to cut a square hole in a tile using a diamond wheel cutting machine. This is useful for when you are tiling and there is a square accessory that requires tiling around.
  • 03:12 Popular Tile cutting using a grinder
    by Admin Added 1,697 Views / 0 Likes
    Angle grinders when used with a diamond tipped disc can be used to cut virtually any type of tile, in this demonstration I cut a curve in a ceramic tile. This method works well on all natural stone tiles such as Marble and Slate but can alsobe used on por
