Tiling videos
Tiling any surface can be difficult without the correct preparation and tools.
This section contains videos showing how to cut and fix most tiles easily and also shows which tools are best for fixing the tiles. Once you know how to cut and fix the tiles correctly the job becomes much easier.
  • 02:46 Popular Cutting tiles on a tile saw
    by Admin Added 1,663 Views / 0 Likes
    A diamond saw can be used to cut virtually any type of tile as demonstrated here
  • 02:46 Popular Diamond coated hole saws
    by Admin Added 1,097 Views / 0 Likes
    Diamond coated hole saws can be used to make large holes in even the toughest of tiles
  • 02:13 Popular Difficult tile cutting
    by Admin Added 1,946 Views / 0 Likes
    How to cut an awkward square shape from a tile using two different types of tile cutter
  • 12:11 Popular Floor tiling
    Floor tiling
    by Admin Added 4,788 Views / 2 Likes
    This video shows how to tile a floor using rapid setting adhesive.
  • 01:26 Popular grout removal using the Bosch PMF 180E
    by Admin Added 1,477 Views / 0 Likes
    How to remove grout from between tiles easily using a bosch pmf 180e or a fein multimaster.
  • 01:32 Popular How to cut a curve in tile using a pair of tile cutting pliers
    by Admin Added 1,725 Views / 0 Likes
    Straight cuts in tiles are easy but to cut a curved tile takes a little more skill. Here a pair of tile cutting pliers are used to cut a curved tile to go around a shower tray.
  • 02:42 Popular How to cut a curved tile using a traditional tile cutter
    Cutting a curved tile may be necessary if you ever need to tile up to a shower encolsure. This video shows how to cut the tile on a traditional tile cutting machine.
  • 02:19 Popular How to cut a square hole in a tile
    by Admin Added 1,827 Views / 0 Likes
    How to cut a square hole in a tile using a diamond wheel cutting machine. This is useful for when you are tiling and there is a square accessory that requires tiling around.
  • 03:45 Popular How to cut tiles with a standard tile cutter
    by Admin Added 1,985 Views / 1 Likes
    How to cut tiles using a standard tile cutter.
  • 02:39 Popular How to drill ceramic tiles
    by Admin Added 1,708 Views / 0 Likes
    Drilling ceramic tiles is normally very easy as they are soft compared to porcelain
  • 04:07 Popular How to drill granite tile
    by Admin Added 330 Views / 0 Likes
    Drilling granite tiles can be very difficult as it is one of the toughest natural stones available, in this video I drill through a 10mm granite tile using a JCB Diamond Tech hole saw. Using the right drill bit for this job is critical as some cheaper dri
  • 04:00 Popular How to drill porcelain tiles
    by Admin Added 1,883 Views / 0 Likes
    Porcelain tiles are tough and difficult to drill. Here we show how to drill them
  • 05:32 Popular How to grout floor tiles
    by Admin Added 2,961 Views / 0 Likes
    Grouting floor tiles can be tricky and needs doing before you walk on the floor times if possible. This video shows how to mix the grout and then apply the grout to the gaps in the tiles.
  • 04:11 Popular How to remove tiles
    How to remove tiles
    by Admin Added 2,788 Views / 1 Likes
    Removing tiles can be tricky, it is best to take a methodical approach rather than going at it like a bull in a china shop. Here we remove wall tiles using a knock through screwdriver and hammer.
  • 19:55 Popular How to tile a bathroom
    by Admin Added 4,304 Views / 1 Likes
    This video shows how to tile a wall and make the all important scribe cuts. Wall tiling is often difficult and can be time consuming. Hopefully this video will help people when they are wall tiling.
  • 10:38 Popular How to tile a kitchen backsplash part 1
    by Admin Added 2,100 Views / 2 Likes
    How to tile a kitchen backsplash part 1 Part 2 can be seen here- http://www.ultimatehandyman.co.uk/video/how-to-tile-a-kitchen-backsplash-part-2-video_2755f789e.html
