Tiling videos
Tiling any surface can be difficult without the correct preparation and tools.
This section contains videos showing how to cut and fix most tiles easily and also shows which tools are best for fixing the tiles. Once you know how to cut and fix the tiles correctly the job becomes much easier.
  • 12:11 Popular Floor tiling
    Floor tiling
    by Admin Added 4,731 Views / 2 Likes
    This video shows how to tile a floor using rapid setting adhesive.
  • 10:38 Popular How to tile a kitchen backsplash part 1
    by Admin Added 2,088 Views / 2 Likes
    How to tile a kitchen backsplash part 1 Part 2 can be seen here- http://www.ultimatehandyman.co.uk/video/how-to-tile-a-kitchen-backsplash-part-2-video_2755f789e.html
  • 03:45 Popular How to cut tiles with a standard tile cutter
    by Admin Added 1,973 Views / 1 Likes
    How to cut tiles using a standard tile cutter.
  • 04:11 Popular How to remove tiles
    How to remove tiles
    by Admin Added 2,768 Views / 1 Likes
    Removing tiles can be tricky, it is best to take a methodical approach rather than going at it like a bull in a china shop. Here we remove wall tiles using a knock through screwdriver and hammer.
  • 14:32 Popular Tanking a shower area
    by Admin Added 2,891 Views / 1 Likes
    Tanking a shower area is always a good idea as water eventually gets behind tiles causing the plasterboard to perish.
  • 04:47 Popular Tiling around pipe entries
    by Admin Added 3,752 Views / 1 Likes
    How to tile around pipe entries, this is useful if you are fitting a wall mounted tap etc.
  • 19:55 Popular How to tile a bathroom
    by Admin Added 4,281 Views / 1 Likes
    This video shows how to tile a wall and make the all important scribe cuts. Wall tiling is often difficult and can be time consuming. Hopefully this video will help people when they are wall tiling.
  • 01:26 Popular grout removal using the Bosch PMF 180E
    by Admin Added 1,466 Views / 0 Likes
    How to remove grout from between tiles easily using a bosch pmf 180e or a fein multimaster.
  • 06:35 Popular Tile grouting
    Tile grouting
    by Admin Added 2,246 Views / 0 Likes
    How to grout tiles
  • 03:12 Popular Tile cutting using a grinder
    by Admin Added 1,758 Views / 0 Likes
    Angle grinders when used with a diamond tipped disc can be used to cut virtually any type of tile, in this demonstration I cut a curve in a ceramic tile. This method works well on all natural stone tiles such as Marble and Slate but can alsobe used on por
  • 02:46 Popular Diamond coated hole saws
    by Admin Added 1,089 Views / 0 Likes
    Diamond coated hole saws can be used to make large holes in even the toughest of tiles
  • 06:55 Popular Installing tile trim on a out of level wall
    by Admin Added 3,472 Views / 0 Likes
    Here a tile trim is fitted to a wall that is not straight, this can be difficult to overcome and so a workaround solution is demonstrated.
  • 02:39 Popular Tile nibblers
    Tile nibblers
    by Admin Added 1,381 Views / 0 Likes
    Tile nibblers are useful for removing small pieces of tile
  • 04:07 Popular How to drill granite tile
    by Admin Added 287 Views / 0 Likes
    Drilling granite tiles can be very difficult as it is one of the toughest natural stones available, in this video I drill through a 10mm granite tile using a JCB Diamond Tech hole saw. Using the right drill bit for this job is critical as some cheaper dri
  • 02:13 Popular Difficult tile cutting
    by Admin Added 1,941 Views / 0 Likes
    How to cut an awkward square shape from a tile using two different types of tile cutter
  • 05:32 Popular How to grout floor tiles
    by Admin Added 2,944 Views / 0 Likes
    Grouting floor tiles can be tricky and needs doing before you walk on the floor times if possible. This video shows how to mix the grout and then apply the grout to the gaps in the tiles.
