Tap videos
Taps are extremely common with most houses having several different types of tap installed.
The videos in this section will show how to install and repair some of the more common types of taps including stop taps and garden taps.
  • 06:10 Popular How to fix a leaking stopcock
    by Admin Added 4,270 Views / 4 Likes
    A stopcock, stop tap or outside tap can ften leak from the gland nut. This video shows hoe to tighten the gland nut ot even repack the gland nut using PTFE tape.
  • 02:42 Popular Removing a seized tap head gear
    by Admin Added 3,593 Views / 4 Likes
    How to remove a seized tap head gear
  • 08:35 Popular How to fit a shower fixing bracket
    by Admin Added 3,168 Views / 3 Likes
    This video shows how to fit a shower mixing bracket. Once the bracket has been fixed the bracket can then be plumbed in, then the shower bar or wall mounted tap can be fixed to it.
  • 08:04 Popular How to replace a single hole lever tap
    by Admin Added 2,849 Views / 2 Likes
    This video shows how to replace a common lever basin tap. These are often called single hole taps as they are installed into a single hole where as many other taps require two fixing holes. This is normally a very simple job and can easily be accomplished
  • 15:10 Popular How to plumb in a wall mounted tap or shower mixer
    by Admin Added 2,468 Views / 2 Likes
    This video shows how to plumb in a wall mounted tap or a shower mixer, this includes fitting isolation valves and double check valves.
  • 05:09 Popular Reseating a tap seat
    by Admin Added 2,480 Views / 2 Likes
    How to reseat a tap using a tap reseating tool
  • 11:34 Popular How to replace taps
    How to replace taps
    by Admin Added 3,317 Views / 1 Likes
    How to replace bason, sink or bath taps
  • 05:48 Popular Replace a tap washer
    by Admin Added 4,455 Views / 1 Likes
    How to replace a tap washer in a traditional tap
  • 03:54 Popular Fitting a wall mounted tap
    by Admin Added 2,714 Views / 0 Likes
    Here we fit a wall mounted tap/shower mixer to a wall.
  • 01:33 Popular How a tap works
    How a tap works
    by Admin Added 2,989 Views / 0 Likes
    This video shows how a traditional kitchen tap works.
  • 06:08 Popular Disabled tap conversion
    by Admin Added 2,566 Views / 0 Likes
    How to convert standard taps to lever taps
  • 02:38 Popular How to replace a stop tap washer
    by Admin Added 2,852 Views / 0 Likes
    If your stop tap is passing ( the water is not isolated with the tap in the closed position ) you probably need to replace the washer. This can only be done when the incoming water can be isolated at a point before the faulty stop tap.
  • 06:14 Popular Tap revivers
    Tap revivers
    by Admin Added 2,615 Views / 0 Likes
    Tap revivers are a quick way to service an old tap
