Silicone Sealant videos
Silicone sealant has built up a kind of love and hate relationship with many DIY’ers.
Many people just cannot get a neat finish with silicone sealant at all. The videos below show how to use a silicone gun and also how to tools the silicone to get a neat finish afterwards.
  • 05:54 Popular How to get a neat silicone line
    by Admin Added 3,770 Views / 2 Likes
    Many people do not like applying silicone sealant, but it can be reasonably easy to apply if you use the correct technique and the correct tools. Here I demonstrate how to use the Fughi kit to get that perfect silicone line that is often so difficult to a
  • 09:51 Popular How silicone around a bath
    by Admin Added 5,578 Views / 1 Likes
    In this video we silicone around a bath This is made much more difficult as the old silicone and also a sealing strip needed removing first. After removing most of the silicone sealant a chemical was applied to remove the rest of the silicone. After the s
  • 04:31 Popular WD-40 versus silicone remover
    by Admin Added 4,034 Views / 1 Likes
    A few people have said that WD-40 works just as well as silicone remover and so I set up this quick comparison. In one test silicone remover was used and in the other WD-40 was used. The WD-40 worked just as well as the silicone remover, perhaps even bett
  • 05:19 Popular How to use a silicone sealant gun
    by Admin Added 4,041 Views / 1 Likes
    How to use a silicone gun to apply silicone sealant or caulk gun
  • 04:58 Popular Fugenboy
    Fugenboy
    by Admin Added 1,829 Views / 0 Likes
    The fugenboy silicone sealant tool means that you can now get professional looking silicone lines with little effort.
  • 01:28 Popular Silicone sealant strength
    by Admin Added 2,351 Views / 0 Likes
    This video shows just how strong traditional silicone sealant can be for fixing
  • 02:42 Popular Clear Silicone Sealant test
    by Admin Added 2,276 Views / 1 Likes
    Sometimes clear silicone sealant is far from clear, here I compare three brands of clear silicone.
  • 04:17 Popular Fixing to tiles using silicone
    by Admin Added 3,007 Views / 0 Likes
    In some instances you can fix items to tiled walls using silicone, this is a quick and easy way and means that the tile does not need drilling.
  • 07:13 Popular How to silicone a shower
    by Admin Added 7,652 Views / 0 Likes
    How to use silicone sealant to seal a shower cubicle.
  • 03:19 Popular Removing silicone sealant
    by Admin Added 4,100 Views / 0 Likes
    Silicone sealant can be difficult to remove but there are now several brands of chemical silicone remover which make the job much easier, this video gives a quick demonstration.
