Powertool Repair videos
Power tools are normally very reliable as long as you buy a decent quality brand but even then things can go wrong and the videos below show how to fix some common problems with power tools.
  • 05:25 Popular Bosch PMF 10.8Li repair
    by Admin Added 2,651 Views / 1 Likes
    This bosch pmf 10,8Li multi tool relies on a sleeve or coupling to transmit power from the motor to the drive shaft of the machine. This sleeve costs about £1 and will prevent your machine from working if it fails.
  • 03:06 Popular Dewalt XRP drill clutch replacement
    by Admin Added 1,757 Views / 0 Likes
    This shows how to replace the clutch or torque unit on a 18v Dewalt drill from the XRP range. There are a few different types of drill in this range and so your drill may be slightly different to this model. If the clutch unit is faulty you may not be abl
  • 03:19 Popular Drill chuck removal
    Drill chuck removal
    by Admin Added 1,748 Views / 2 Likes
    Removing a drill chuck using an impact wrench
  • 03:59 Popular How to change a motor start capacitor
    by Admin Added 858 Views / 0 Likes
    Motor start capacitors are often found on single phase motors, in this video we replace the start capacitor on a single phase compressor.
  • 03:15 Popular How to replace a gearbox in a Dewalt XRP drill
    by Admin Added 1,962 Views / 0 Likes
    Here we replace the gearbox, clutch and chuck on a Dewalt 18v XRP drill as one complete unit. This is extremely useful if the gearbox on your drill is damaged.
  • 09:18 Popular How to replace a power tool flex
    by Admin Added 1,402 Views / 0 Likes
    How to replace a damaged fex on a mains voltage power tool
  • 02:38 Popular How to replace the brushes in a Dewalt Angle grinder | Dewalt DW 490
    by Admin Added 1,889 Views / 0 Likes
    How to replace the brushes in a Dewalt angle grinder.
  • 06:44 Popular How to replace the brushes in the Dewalt DW006 24v drill
    by Admin Added 1,203 Views / 0 Likes
    It is inevitable that drill brushes will eventually wear out, which can cause irreparable damage to the drill. This video shows how to change the brushes in the Dewalt DW006, which is one of the harder Dewalt tools to change the brushes on.
  • 15:22 Popular Powertool electrical fault finding
    by Admin Added 2,026 Views / 0 Likes
    This video shows how to fault find on a dewalt angle grinder and replace the faulty component, which in this case was the switch.
  • 04:39 Popular Replacing Dewalt cordless drill brushes.
    by Admin Added 1,988 Views / 1 Likes
    How to replace the brushes in a Dewalt cordless drill
