  • 09:39 Popular How to use push fit pipe | JG speedfit
    by Admin Added 1,453 Views / 1 Likes
    In this video I demonstrate how to cut and join plastic push fit pipe, the pipe used is John Guest speedfit pipe and JG speedfit fittings. PEX barrier pipe is now very common and many plumbers will only install this type of pipe unless copper pipe is spec
  • 01:40 Popular How to measure water pressure
    by Admin Added 1,149 Views / 0 Likes
    Water pressure can easily be measured using a relatively inexpensive water pressure test gauge which costs approximately £10 http://fave.co/1IPpqKm You might want to know how much pressure you have, if you are fitting a new appliance etc. High water
  • 02:12 Popular Water pressure versus water flow
    by Admin Added 1,140 Views / 1 Likes
    It’s easy to get confused between water pressure and water flow. Many times you will hear people say that they are going to close their stop tap to reduce the pressure. Whilst it is possible to reduce the pressure slightly with a stop tap you are ac
  • 05:10 Popular How to unblock a drain using drain rods
    by Admin Added 933 Views / 0 Likes
    Rain water drains can soon become blocked with leaves and soil etc. This waste settles in the trap beneath the drain and causes the pipe to block. In extreme cases this can cause your property to flood, so it’s essential to check all drains around t
  • 05:15 Popular The easiest way to fix a burst pipe
    by Admin Added 601 Views / 0 Likes
    In this video I repair a burst copper pipe using two JG speedfit couplings and a piece of Speedfit pipe. This pipe burst a couple of weeks previously in my mate’s garage and nearly flooded the place. He did try to call out 5 plumbers but none of the
  • 06:06 Popular How to repair a hole in a copper pipe using a click fix patch repair
    by Admin Added 518 Views / 1 Likes
    In this video I repair a hole in a copper pipe using a flowflex copper click fix 15mm pipe repair patch. These are a superb way of repairing damaged pipes as the existing copper pipe does not need to be cut in order to make the repair. These fittings are
  • 10:42 Popular How to use slip couplings to tee into a pipe that cannot be moved
    by Admin Added 494 Views / 0 Likes
    In this video I use two slip couplings to tee into a rigid copper pipe. Slip couplings are useful for joining into any rigid copper pipe as they allow a new fitting or piece of pipe to be inserted into a pipe which cannot be moved. The fittings used in th
  • 03:43 Popular how to drill a hole in a cast iron soil pipe
    by Admin Added 492 Views / 0 Likes
    In this video I cut a 57mm diameter hole in a cast iron soil stack pipe. This can be difficult to do as cast iron is tough compared to todays modern plastics. To cut the hole I have used a Starrett 57mm Bi-metal hole saw and arbour. Ideally this job would
  • 03:29 Popular How to install a mechanical boss | cast iron pipe boss
    by Admin Added 467 Views / 0 Likes
    In this video I install a mechanical boss onto a cast iron soil pipe. How to cut the 57mm hole in the soil pipe can be seen here- https://www.youtube.com/watch?v=xm0GGDsw2OU A mechanical boss can be used to connect a waste pipe, either 32mm or 40mm into a
  • 06:04 Popular Solder ring fittings | Yorkshire fittings | capillary fittings
    by Admin Added 329 Views / 0 Likes
    In this video I take a look at some Yorkshire fittings, often known as solder ring fittings or capillary fittings. These types of fittings are very popular in the UK and have been around for several decades. For some reason these fittings are not common i
  • 02:48 How to fix a toilet that keeps running
    by Admin Added 95 Views / 0 Likes
    A toilet that keeps running can often be fixed easily by simply adding some liquid soap to the water in the cistern. Often the parts in the system start to stick, this can often be helped by adding some liquid soap, which lubricates the plastic parts. In
  • 08:30 How to fix a leaking radiator valve nut
    by Admin Added 80 Views / 0 Likes
    In this video I repair a leaking radiator valve nut by wrapping some PTFE tape around the olive. It is quite common for radiator valves to leak via the nut/olive or pipe, especially on small bore pipes such as microbore.
  • 04:43 How to cut cast iron pipe using a chisel
    by Admin Added 72 Views / 0 Likes
    In this video I attempt to cut a piece of cast iron pipe using a cold chisel and club hammer. The cast iron pipe is very old and is probably at least 50 years old. I recently got a NVQ level 2 booklet which showed how to cut cast iron pipe this way, obvio
