  • 04:26 Popular Plastic pipe for plumbing
    by Admin Added 2,504 Views / 0 Likes
    Plastic pipe is now very common, this video shows how to join it together
  • 02:44 Popular How to bend copper tube
    by Admin Added 2,467 Views / 0 Likes
    Coppertube can be bent with a dedicated tube bending machine or for simple bends you can use a pipe bending spring.
  • 09:36 Popular Replacing a lead water pipe
    by Admin Added 2,443 Views / 1 Likes
    How to replace a lead water supply pipe with a MDPE pipe. Before doing this you need to contact the utility company that supplies you with water and get advice from them. United utilities are my supplier and they run a lead pipe replacement scheme where y
  • 08:11 Popular How to use a pipe bender
    by Admin Added 2,426 Views / 0 Likes
    Bending copper pipe can be difficult with a pipe bending spring, where possible a dedicated pipe bender should be used as these machines can make bending copper pipes much easier and more accurate.
  • 03:52 Popular Solder chrome pipe
    Solder chrome pipe
    by Admin Added 2,326 Views / 0 Likes
    Chrome pipe is difficult to join using solder or push fit fittings unless you remove the chrome first, this video shows how to remove the chrome plating
  • 01:54 Popular Cutting copper pipe using a pipe slice
    by Admin Added 2,325 Views / 0 Likes
    How to cut and join copper pipe ready for making a joint
  • 04:09 Popular How to replace a cartridge in a quarter turn tap
    by Admin Added 2,231 Views / 1 Likes
    How to change the ceramic cartridge in a quarter turn tap. Often these types of taps leak and there is no washer to change and so you have to replace the ceramic cartridge. This cartridge at my local plumbers merchants was £2 at a large DIY store it
    by Admin Added 2,222 Views / 0 Likes
  • 02:56 Popular Joining chrome pipe
    Joining chrome pipe
    by Admin Added 2,172 Views / 0 Likes
    Chrome pipe can be difficult to join, this video explains why
  • 04:26 Popular How to Solvent weld pipes
    by Admin Added 2,045 Views / 1 Likes
    Solvent weld pipes are common in many homes, they come in various sizes and once the joint is made they are normally very reliable. Here we join a piece of 32mm solvent weld waste pipe using solvent cement.
  • 06:19 Popular How to repair a Leaking lead pipe | Leadloc
    by Admin Added 1,966 Views / 0 Likes
    Lead pipe is still found in many properties in Britain, these pipes can leak when disturbed and it can be difficult to repair a lead pipe. Here we repair the pipe by cutting off the damaged section and then we fit a leadloc fitting which is specifically d
  • 02:37 Popular Push-Loc MDPE fittings
    by Admin Added 1,920 Views / 0 Likes
    Push-Loc by Melimatic is a range of push on brass fittings for use on MDPE pipe. These fittings are good quality and are easy to use, with the added advantage that they are much smaller than traditional push-fit fittings. These fittings also do not requir
  • 05:28 Popular Surface drain unblocking
    by Admin Added 1,722 Views / 0 Likes
    Surface drains can easily become blocked with debris, therefore it is a good idea to clear them before they get blocked and cause problems. Often this is simply a case of lifting off the covers and removing the debris.
  • 05:38 Popular How to unblock a sink or basin
    by Admin Added 1,665 Views / 1 Likes
    In this video we try several popular methods of unblocking a sink that is difficult to unblock. Normally a plunger will work in most cases but there is always one sink or basin that just will not unblock. Here several methods are tried in order to remove
  • 04:43 Popular Immersion heater element removal
    by Admin Added 1,585 Views / 1 Likes
    In this video Razor demonstrates how to remove an immersion heater element from a copper cylinder.
  • 01:21 Popular Power Plumber
    Power Plumber
    by Admin Added 1,583 Views / 0 Likes
    power plumber is a quick and easy way to unblock a sink or basin
