    by Admin Added 2,188 Views / 0 Likes
  • 01:38 Popular How to use compression fittings
    by Admin Added 3,556 Views / 0 Likes
    Compression fittings are a quick and easy way to join pipes, they can be used on copper pipes or plastic pipes (with inserts)
  • 02:10 Popular How to use PTFE tape
    by Admin Added 2,894 Views / 0 Likes
    How to use PTFE tape when assembling threaded components
  • 09:39 Popular How to use push fit pipe | JG speedfit
    by Admin Added 1,350 Views / 1 Likes
    In this video I demonstrate how to cut and join plastic push fit pipe, the pipe used is John Guest speedfit pipe and JG speedfit fittings. PEX barrier pipe is now very common and many plumbers will only install this type of pipe unless copper pipe is spec
  • 10:42 Popular How to use slip couplings to tee into a pipe that cannot be moved
    by Admin Added 455 Views / 0 Likes
    In this video I use two slip couplings to tee into a rigid copper pipe. Slip couplings are useful for joining into any rigid copper pipe as they allow a new fitting or piece of pipe to be inserted into a pipe which cannot be moved. The fittings used in th
  • 04:43 Popular Immersion heater element removal
    by Admin Added 1,553 Views / 1 Likes
    In this video Razor demonstrates how to remove an immersion heater element from a copper cylinder.
  • 02:56 Popular Joining chrome pipe
    Joining chrome pipe
    by Admin Added 2,127 Views / 0 Likes
    Chrome pipe can be difficult to join, this video explains why
  • 04:21 Popular Just for copper | solderless copper bonding
    by Admin Added 2,618 Views / 0 Likes
    How to join copper pipes using just for copper, which is a solderless bonding solution. This is useful in areas where a blowtorch cannot be used.
  • 02:09 Popular Never trust a single isolation valve
    by Admin Added 3,194 Views / 1 Likes
    This isolation valve was in the closed position, but on removing the flexi connector it became apparent that the valve was not closed at all.
  • 04:26 Popular Plastic pipe for plumbing
    by Admin Added 2,474 Views / 0 Likes
    Plastic pipe is now very common, this video shows how to join it together
  • 01:21 Popular Power Plumber
    Power Plumber
    by Admin Added 1,564 Views / 0 Likes
    power plumber is a quick and easy way to unblock a sink or basin
  • 02:37 Popular Push-Loc MDPE fittings
    by Admin Added 1,875 Views / 0 Likes
    Push-Loc by Melimatic is a range of push on brass fittings for use on MDPE pipe. These fittings are good quality and are easy to use, with the added advantage that they are much smaller than traditional push-fit fittings. These fittings also do not requir
  • 02:42 Popular Removing a seized tap head gear
    by Admin Added 3,658 Views / 4 Likes
    How to remove a seized tap head gear
  • 05:48 Popular Replace a tap washer
    by Admin Added 4,504 Views / 1 Likes
    How to replace a tap washer in a traditional tap
  • 09:36 Popular Replacing a lead water pipe
    by Admin Added 2,411 Views / 1 Likes
    How to replace a lead water supply pipe with a MDPE pipe. Before doing this you need to contact the utility company that supplies you with water and get advice from them. United utilities are my supplier and they run a lead pipe replacement scheme where y
  • 05:09 Popular Reseating a tap seat
    by Admin Added 2,525 Views / 2 Likes
    How to reseat a tap using a tap reseating tool
