  • 01:40 Popular How to measure water pressure
    by Admin Added 1,148 Views / 0 Likes
    Water pressure can easily be measured using a relatively inexpensive water pressure test gauge which costs approximately £10 http://fave.co/1IPpqKm You might want to know how much pressure you have, if you are fitting a new appliance etc. High water
  • 01:21 Popular Power Plumber
    Power Plumber
    by Admin Added 1,583 Views / 0 Likes
    power plumber is a quick and easy way to unblock a sink or basin
  • 08:11 Popular How to use a pipe bender
    by Admin Added 2,426 Views / 0 Likes
    Bending copper pipe can be difficult with a pipe bending spring, where possible a dedicated pipe bender should be used as these machines can make bending copper pipes much easier and more accurate.
  • 08:30 How to fix a leaking radiator valve nut
    by Admin Added 79 Views / 0 Likes
    In this video I repair a leaking radiator valve nut by wrapping some PTFE tape around the olive. It is quite common for radiator valves to leak via the nut/olive or pipe, especially on small bore pipes such as microbore.
  • 01:23 Popular copper pushfit fittings | cuprofit
    by Admin Added 14.9k Views / 0 Likes
    Copper push fit fittings look just like normal copper fittings, here we connect two pipes using cuprofit connectors
  • 00:56 Popular Stopcock opening/closing | Stop tap opening/closing
    by Admin Added 2,707 Views / 0 Likes
    A quick tip when opening a stopcock is to never open it fully as you run the risk of it seizing in the fully open position.
  • 05:15 Popular How to install a shower waste trap
    by Admin Added 2,852 Views / 0 Likes
    This video shows how to install a McAlpine waste trap to a quadrant shower tray.
  • 10:42 Popular How to use slip couplings to tee into a pipe that cannot be moved
    by Admin Added 494 Views / 0 Likes
    In this video I use two slip couplings to tee into a rigid copper pipe. Slip couplings are useful for joining into any rigid copper pipe as they allow a new fitting or piece of pipe to be inserted into a pipe which cannot be moved. The fittings used in th
  • 01:38 Popular How to use compression fittings
    by Admin Added 3,605 Views / 0 Likes
    Compression fittings are a quick and easy way to join pipes, they can be used on copper pipes or plastic pipes (with inserts)
    by Admin Added 2,222 Views / 0 Likes
  • 04:43 How to cut cast iron pipe using a chisel
    by Admin Added 71 Views / 0 Likes
    In this video I attempt to cut a piece of cast iron pipe using a cold chisel and club hammer. The cast iron pipe is very old and is probably at least 50 years old. I recently got a NVQ level 2 booklet which showed how to cut cast iron pipe this way, obvio
  • 01:54 Popular Cutting copper pipe using a pipe slice
    by Admin Added 2,325 Views / 0 Likes
    How to cut and join copper pipe ready for making a joint
  • 05:28 Popular Surface drain unblocking
    by Admin Added 1,722 Views / 0 Likes
    Surface drains can easily become blocked with debris, therefore it is a good idea to clear them before they get blocked and cause problems. Often this is simply a case of lifting off the covers and removing the debris.
  • 02:05 Popular How to isolate a central heating header tank
    by Admin Added 2,742 Views / 0 Likes
    If you need to isolate your central heating header tank this video shows how to do it when there is no isolation valve.
  • 06:04 Popular Solder ring fittings | Yorkshire fittings | capillary fittings
    by Admin Added 329 Views / 0 Likes
    In this video I take a look at some Yorkshire fittings, often known as solder ring fittings or capillary fittings. These types of fittings are very popular in the UK and have been around for several decades. For some reason these fittings are not common i
  • 05:10 Popular How to unblock a drain using drain rods
    by Admin Added 933 Views / 0 Likes
    Rain water drains can soon become blocked with leaves and soil etc. This waste settles in the trap beneath the drain and causes the pipe to block. In extreme cases this can cause your property to flood, so it’s essential to check all drains around t
