  • 02:09 Popular Never trust a single isolation valve
    by Admin Added 3,030 Views / 0 Likes
    This isolation valve was in the closed position, but on removing the flexi connector it became apparent that the valve was not closed at all.
  • 02:02 Popular How to connect flexi tails
    by Admin Added 2,947 Views / 0 Likes
    Flexi tails are now very common, here we show what the various types can be connected to
  • 05:00 Popular How to join any water pipe | Philmac UTC
    by Admin Added 2,881 Views / 1 Likes
    It is now possible to join virtually any pipe to any pipe using the philmac universal transitional coupling. You do not need to worry about the pipe being metric or imperial as the UTC an connect either pipe. The UTC’s are available in a variety of
  • 02:38 Popular How to replace a stop tap washer
    by Admin Added 2,718 Views / 0 Likes
    If your stop tap is passing ( the water is not isolated with the tap in the closed position ) you probably need to replace the washer. This can only be done when the incoming water can be isolated at a point before the faulty stop tap.
  • 02:10 Popular How to use PTFE tape
    by Admin Added 2,619 Views / 0 Likes
    How to use PTFE tape when assembling threaded components
  • 08:05 Popular Shower tray install on mortar
    by Admin Added 2,596 Views / 3 Likes
    Many shower trays require installing onto a bed of mortar (cement), this video shows how to install such a shower tray onto a wooden floor.
  • 05:15 Popular How to install a shower waste trap
    by Admin Added 2,579 Views / 0 Likes
    This video shows how to install a McAlpine waste trap to a quadrant shower tray.
  • 02:01 Popular How to Solder using a heat gun
    by Admin Added 2,550 Views / 1 Likes
    A heat gun is often much safer than using a blow torch, here I solder two pipes together using a solder ring fitting
  • 01:35 Popular Sink unblocking
    Sink unblocking
    by Admin Added 2,547 Views / 0 Likes
    Unblocking a sink can be done quickly using a plunger
  • 08:04 Popular How to replace a single hole lever tap
    by Admin Added 2,472 Views / 2 Likes
    This video shows how to replace a common lever basin tap. These are often called single hole taps as they are installed into a single hole where as many other taps require two fixing holes. This is normally a very simple job and can easily be accomplished
  • 02:05 Popular How to isolate a central heating header tank
    by Admin Added 2,466 Views / 0 Likes
    If you need to isolate your central heating header tank this video shows how to do it when there is no isolation valve.
  • 06:08 Popular Disabled tap conversion
    by Admin Added 2,430 Views / 0 Likes
    How to convert standard taps to lever taps
  • 06:14 Popular Tap revivers
    Tap revivers
    by Admin Added 2,415 Views / 0 Likes
    Tap revivers are a quick way to service an old tap
  • 04:21 Popular Just for copper | solderless copper bonding
    by Admin Added 2,398 Views / 0 Likes
    How to join copper pipes using just for copper, which is a solderless bonding solution. This is useful in areas where a blowtorch cannot be used.
  • 00:56 Popular Stopcock opening/closing | Stop tap opening/closing
    by Admin Added 2,369 Views / 0 Likes
    A quick tip when opening a stopcock is to never open it fully as you run the risk of it seizing in the fully open position.
  • 04:26 Popular Plastic pipe for plumbing
    by Admin Added 2,347 Views / 0 Likes
    Plastic pipe is now very common, this video shows how to join it together
