  • 01:40 Popular How to measure water pressure
    by Admin Added 915 Views / 0 Likes
    Water pressure can easily be measured using a relatively inexpensive water pressure test gauge which costs approximately £10 http://fave.co/1IPpqKm You might want to know how much pressure you have, if you are fitting a new appliance etc. High water
  • 06:19 Popular How to repair a Leaking lead pipe | Leadloc
    by Admin Added 1,808 Views / 0 Likes
    Lead pipe is still found in many properties in Britain, these pipes can leak when disturbed and it can be difficult to repair a lead pipe. Here we repair the pipe by cutting off the damaged section and then we fit a leadloc fitting which is specifically d
  • 04:09 Popular How to replace a cartridge in a quarter turn tap
    by Admin Added 1,958 Views / 1 Likes
    How to change the ceramic cartridge in a quarter turn tap. Often these types of taps leak and there is no washer to change and so you have to replace the ceramic cartridge. This cartridge at my local plumbers merchants was £2 at a large DIY store it
  • 08:04 Popular How to replace a single hole lever tap
    by Admin Added 2,393 Views / 2 Likes
    This video shows how to replace a common lever basin tap. These are often called single hole taps as they are installed into a single hole where as many other taps require two fixing holes. This is normally a very simple job and can easily be accomplished
  • 02:38 Popular How to replace a stop tap washer
    by Admin Added 2,687 Views / 0 Likes
    If your stop tap is passing ( the water is not isolated with the tap in the closed position ) you probably need to replace the washer. This can only be done when the incoming water can be isolated at a point before the faulty stop tap.
  • 11:34 Popular How to replace taps
    How to replace taps
    by Admin Added 3,087 Views / 1 Likes
    How to replace bason, sink or bath taps
  • 03:05 Popular How to solder a wet pipe
    by Admin Added 3,391 Views / 0 Likes
    A common problem when doing plumbing is how to solder a wet pipe, this can be a real problem especially if you cut into a downstairs copper pipe as the rest of the pipes in the house can take hours to drain fully. Obviously the pipe needs to be dry before
  • 06:00 Popular How to Solder copper pipe
    by Admin Added 7,483 Views / 0 Likes
    How to solder copper pipe using solder ring fittings
  • 02:01 Popular How to Solder using a heat gun
    by Admin Added 2,500 Views / 1 Likes
    A heat gun is often much safer than using a blow torch, here I solder two pipes together using a solder ring fitting
  • 04:26 Popular How to Solvent weld pipes
    by Admin Added 1,927 Views / 1 Likes
    Solvent weld pipes are common in many homes, they come in various sizes and once the joint is made they are normally very reliable. Here we join a piece of 32mm solvent weld waste pipe using solvent cement.
  • 05:10 Popular How to unblock a drain using drain rods
    by Admin Added 704 Views / 0 Likes
    Rain water drains can soon become blocked with leaves and soil etc. This waste settles in the trap beneath the drain and causes the pipe to block. In extreme cases this can cause your property to flood, so it’s essential to check all drains around t
  • 05:38 Popular How to unblock a sink or basin
    by Admin Added 1,481 Views / 1 Likes
    In this video we try several popular methods of unblocking a sink that is difficult to unblock. Normally a plunger will work in most cases but there is always one sink or basin that just will not unblock. Here several methods are tried in order to remove
  • 08:11 Popular How to use a pipe bender
    by Admin Added 2,113 Views / 0 Likes
    Bending copper pipe can be difficult with a pipe bending spring, where possible a dedicated pipe bender should be used as these machines can make bending copper pipes much easier and more accurate.
    by Admin Added 1,967 Views / 0 Likes
  • 01:38 Popular How to use compression fittings
    by Admin Added 3,270 Views / 0 Likes
    Compression fittings are a quick and easy way to join pipes, they can be used on copper pipes or plastic pipes (with inserts)
  • 02:10 Popular How to use PTFE tape
    by Admin Added 2,595 Views / 0 Likes
    How to use PTFE tape when assembling threaded components
