  • 06:08 Popular How to install a bath waste
    by Admin Added 5,032 Views / 1 Likes
    This video shows How to install a pop up waste to an L shaped bath.
  • 02:01 Popular How to Solder using a heat gun
    by Admin Added 2,703 Views / 1 Likes
    A heat gun is often much safer than using a blow torch, here I solder two pipes together using a solder ring fitting
  • 04:43 Popular Immersion heater element removal
    by Admin Added 1,566 Views / 1 Likes
    In this video Razor demonstrates how to remove an immersion heater element from a copper cylinder.
  • 05:00 Popular How to join any water pipe | Philmac UTC
    by Admin Added 3,040 Views / 1 Likes
    It is now possible to join virtually any pipe to any pipe using the philmac universal transitional coupling. You do not need to worry about the pipe being metric or imperial as the UTC an connect either pipe. The UTC’s are available in a variety of
  • 06:06 Popular How to repair a hole in a copper pipe using a click fix patch repair
    by Admin Added 496 Views / 1 Likes
    In this video I repair a hole in a copper pipe using a flowflex copper click fix 15mm pipe repair patch. These are a superb way of repairing damaged pipes as the existing copper pipe does not need to be cut in order to make the repair. These fittings are
  • 05:32 Popular How to install a basin waste
    by Admin Added 4,939 Views / 2 Likes
    Installing a basin waste can be difficult especially if you try to use the sealing washers that are supplied with the basin waste. Here we fit a pop up waste into a square vanity unit basin.
  • 02:09 Popular Never trust a single isolation valve
    by Admin Added 3,210 Views / 1 Likes
    This isolation valve was in the closed position, but on removing the flexi connector it became apparent that the valve was not closed at all.
  • 05:15 Popular How to install a shower waste trap
    by Admin Added 2,834 Views / 0 Likes
    This video shows how to install a McAlpine waste trap to a quadrant shower tray.
  • 10:42 Popular How to use slip couplings to tee into a pipe that cannot be moved
    by Admin Added 477 Views / 0 Likes
    In this video I use two slip couplings to tee into a rigid copper pipe. Slip couplings are useful for joining into any rigid copper pipe as they allow a new fitting or piece of pipe to be inserted into a pipe which cannot be moved. The fittings used in th
  • 01:38 Popular How to use compression fittings
    by Admin Added 3,572 Views / 0 Likes
    Compression fittings are a quick and easy way to join pipes, they can be used on copper pipes or plastic pipes (with inserts)
  • 01:54 Popular Cutting copper pipe using a pipe slice
    by Admin Added 2,287 Views / 0 Likes
    How to cut and join copper pipe ready for making a joint
  • 05:28 Popular Surface drain unblocking
    by Admin Added 1,711 Views / 0 Likes
    Surface drains can easily become blocked with debris, therefore it is a good idea to clear them before they get blocked and cause problems. Often this is simply a case of lifting off the covers and removing the debris.
    by Admin Added 2,207 Views / 0 Likes
  • 04:43 New How to cut cast iron pipe using a chisel
    by Admin Added 9 Views / 0 Likes
    In this video I attempt to cut a piece of cast iron pipe using a cold chisel and club hammer. The cast iron pipe is very old and is probably at least 50 years old. I recently got a NVQ level 2 booklet which showed how to cut cast iron pipe this way, obvio
  • 02:05 Popular How to isolate a central heating header tank
    by Admin Added 2,713 Views / 0 Likes
    If you need to isolate your central heating header tank this video shows how to do it when there is no isolation valve.
  • 06:04 Popular Solder ring fittings | Yorkshire fittings | capillary fittings
    by Admin Added 301 Views / 0 Likes
    In this video I take a look at some Yorkshire fittings, often known as solder ring fittings or capillary fittings. These types of fittings are very popular in the UK and have been around for several decades. For some reason these fittings are not common i
