  • 01:23 Popular copper pushfit fittings | cuprofit
    by Admin Added 13.7k Views / 0 Likes
    Copper push fit fittings look just like normal copper fittings, here we connect two pipes using cuprofit connectors
  • 04:15 Popular How to cut and join MDPE pipe
    by Admin Added 12.1k Views / 0 Likes
    This video shows how to cut and join MDPE pipe using two popular types of fitting, John Guest speed fit and Melimatic Push-Loc.
  • 06:00 Popular How to Solder copper pipe
    by Admin Added 7,759 Views / 0 Likes
    How to solder copper pipe using solder ring fittings
  • 01:57 Popular Cutting pipes beneath floors | Rubble sack
    by Admin Added 6,591 Views / 1 Likes
    A quick tip when cutting pipes beneath floors that contain water it is often difficult catching the water, without it spilling onto the ceiling below. A rubble sack is the perfect answer as it is flexible and waterproof.
  • 06:08 Popular How to install a bath waste
    by Admin Added 4,855 Views / 1 Likes
    This video shows How to install a pop up waste to an L shaped bath.
  • 05:32 Popular How to install a basin waste
    by Admin Added 4,829 Views / 2 Likes
    Installing a basin waste can be difficult especially if you try to use the sealing washers that are supplied with the basin waste. Here we fit a pop up waste into a square vanity unit basin.
  • 12:39 Popular How to install a bath
    by Admin Added 4,502 Views / 2 Likes
    This video shows how to fit an L shaped bath. It can be time consuming to fit but it is worth spending the time to get the bath in the correct position and level. Once fitted correctly and sealed correctly your bath should last for years.
  • 05:48 Popular Replace a tap washer
    by Admin Added 4,456 Views / 1 Likes
    How to replace a tap washer in a traditional tap
  • 06:10 Popular How to fix a leaking stopcock
    by Admin Added 4,272 Views / 4 Likes
    A stopcock, stop tap or outside tap can ften leak from the gland nut. This video shows hoe to tighten the gland nut ot even repack the gland nut using PTFE tape.
  • 02:00 Popular shower waste cleaning
    by Admin Added 3,860 Views / 0 Likes
    How to clean a waste trap from a shower.
  • 03:05 Popular How to solder a wet pipe
    by Admin Added 3,815 Views / 0 Likes
    A common problem when doing plumbing is how to solder a wet pipe, this can be a real problem especially if you cut into a downstairs copper pipe as the rest of the pipes in the house can take hours to drain fully. Obviously the pipe needs to be dry before
  • 02:42 Popular Removing a seized tap head gear
    by Admin Added 3,596 Views / 4 Likes
    How to remove a seized tap head gear
  • 01:38 Popular How to use compression fittings
    by Admin Added 3,514 Views / 0 Likes
    Compression fittings are a quick and easy way to join pipes, they can be used on copper pipes or plastic pipes (with inserts)
  • 01:51 Popular Cutting plastic pushfit pipe | John guest pipe
    by Admin Added 3,379 Views / 0 Likes
    How to cut plastic pushfit pipe ready for joining
  • 11:34 Popular How to replace taps
    How to replace taps
    by Admin Added 3,321 Views / 1 Likes
    How to replace bason, sink or bath taps
  • 06:41 Popular How to join Waste pipe
    by Admin Added 3,282 Views / 1 Likes
    Waste pipes typically come in 32mm and 40mm sizes for domestic properties, but 32mm solvent weld pipe and 32mm push fit pipe is not the same size and so people often get confused when trying to join the two together.
