  • 01:23 Popular copper pushfit fittings | cuprofit
    by Admin Added 13.4k Views / 0 Likes
    Copper push fit fittings look just like normal copper fittings, here we connect two pipes using cuprofit connectors
  • 01:54 Popular Cutting copper pipe using a pipe slice
    by Admin Added 2,150 Views / 0 Likes
    How to cut and join copper pipe ready for making a joint
  • 01:57 Popular Cutting pipes beneath floors | Rubble sack
    by Admin Added 6,578 Views / 1 Likes
    A quick tip when cutting pipes beneath floors that contain water it is often difficult catching the water, without it spilling onto the ceiling below. A rubble sack is the perfect answer as it is flexible and waterproof.
  • 01:51 Popular Cutting plastic pushfit pipe | John guest pipe
    by Admin Added 3,353 Views / 0 Likes
    How to cut plastic pushfit pipe ready for joining
  • 06:08 Popular Disabled tap conversion
    by Admin Added 2,547 Views / 0 Likes
    How to convert standard taps to lever taps
  • 02:44 Popular How to bend copper tube
    by Admin Added 2,381 Views / 0 Likes
    Coppertube can be bent with a dedicated tube bending machine or for simple bends you can use a pipe bending spring.
  • 02:02 Popular How to connect flexi tails
    by Admin Added 3,058 Views / 0 Likes
    Flexi tails are now very common, here we show what the various types can be connected to
  • 04:15 Popular How to cut and join MDPE pipe
    by Admin Added 12k Views / 0 Likes
    This video shows how to cut and join MDPE pipe using two popular types of fitting, John Guest speed fit and Melimatic Push-Loc.
  • 03:43 Popular how to drill a hole in a cast iron soil pipe
    by Admin Added 176 Views / 0 Likes
    In this video I cut a 57mm diameter hole in a cast iron soil stack pipe. This can be difficult to do as cast iron is tough compared to todays modern plastics. To cut the hole I have used a Starrett 57mm Bi-metal hole saw and arbour. Ideally this job would
  • 06:10 Popular How to fix a leaking stopcock
    by Admin Added 4,238 Views / 4 Likes
    A stopcock, stop tap or outside tap can ften leak from the gland nut. This video shows hoe to tighten the gland nut ot even repack the gland nut using PTFE tape.
  • 05:32 Popular How to install a basin waste
    by Admin Added 4,794 Views / 2 Likes
    Installing a basin waste can be difficult especially if you try to use the sealing washers that are supplied with the basin waste. Here we fit a pop up waste into a square vanity unit basin.
  • 12:39 Popular How to install a bath
    by Admin Added 4,476 Views / 2 Likes
    This video shows how to fit an L shaped bath. It can be time consuming to fit but it is worth spending the time to get the bath in the correct position and level. Once fitted correctly and sealed correctly your bath should last for years.
  • 06:08 Popular How to install a bath waste
    by Admin Added 4,823 Views / 1 Likes
    This video shows How to install a pop up waste to an L shaped bath.
  • 03:29 Popular How to install a mechanical boss | cast iron pipe boss
    by Admin Added 190 Views / 0 Likes
    In this video I install a mechanical boss onto a cast iron soil pipe. How to cut the 57mm hole in the soil pipe can be seen here- https://www.youtube.com/watch?v=xm0GGDsw2OU A mechanical boss can be used to connect a waste pipe, either 32mm or 40mm into a
  • 05:15 Popular How to install a shower waste trap
    by Admin Added 2,737 Views / 0 Likes
    This video shows how to install a McAlpine waste trap to a quadrant shower tray.
  • 02:05 Popular How to isolate a central heating header tank
    by Admin Added 2,598 Views / 0 Likes
    If you need to isolate your central heating header tank this video shows how to do it when there is no isolation valve.
