  • 02:42 Popular Removing a seized tap head gear
    by Admin Added 3,562 Views / 4 Likes
    How to remove a seized tap head gear
  • 06:10 Popular How to fix a leaking stopcock
    by Admin Added 4,240 Views / 4 Likes
    A stopcock, stop tap or outside tap can ften leak from the gland nut. This video shows hoe to tighten the gland nut ot even repack the gland nut using PTFE tape.
  • 08:05 Popular Shower tray install on mortar
    by Admin Added 2,752 Views / 3 Likes
    Many shower trays require installing onto a bed of mortar (cement), this video shows how to install such a shower tray onto a wooden floor.
  • 12:39 Popular How to install a bath
    by Admin Added 4,482 Views / 2 Likes
    This video shows how to fit an L shaped bath. It can be time consuming to fit but it is worth spending the time to get the bath in the correct position and level. Once fitted correctly and sealed correctly your bath should last for years.
  • 08:04 Popular How to replace a single hole lever tap
    by Admin Added 2,681 Views / 2 Likes
    This video shows how to replace a common lever basin tap. These are often called single hole taps as they are installed into a single hole where as many other taps require two fixing holes. This is normally a very simple job and can easily be accomplished
  • 05:09 Popular Reseating a tap seat
    by Admin Added 2,465 Views / 2 Likes
    How to reseat a tap using a tap reseating tool
  • 01:57 Popular Cutting pipes beneath floors | Rubble sack
    by Admin Added 6,580 Views / 1 Likes
    A quick tip when cutting pipes beneath floors that contain water it is often difficult catching the water, without it spilling onto the ceiling below. A rubble sack is the perfect answer as it is flexible and waterproof.
  • 05:38 Popular How to unblock a sink or basin
    by Admin Added 1,590 Views / 1 Likes
    In this video we try several popular methods of unblocking a sink that is difficult to unblock. Normally a plunger will work in most cases but there is always one sink or basin that just will not unblock. Here several methods are tried in order to remove
  • 09:39 Popular How to use push fit pipe | JG speedfit
    by Admin Added 1,087 Views / 1 Likes
    In this video I demonstrate how to cut and join plastic push fit pipe, the pipe used is John Guest speedfit pipe and JG speedfit fittings. PEX barrier pipe is now very common and many plumbers will only install this type of pipe unless copper pipe is spec
  • 11:34 Popular How to replace taps
    How to replace taps
    by Admin Added 3,296 Views / 1 Likes
    How to replace bason, sink or bath taps
  • 06:08 Popular How to install a bath waste
    by Admin Added 4,828 Views / 1 Likes
    This video shows How to install a pop up waste to an L shaped bath.
  • 02:01 Popular How to Solder using a heat gun
    by Admin Added 2,645 Views / 1 Likes
    A heat gun is often much safer than using a blow torch, here I solder two pipes together using a solder ring fitting
  • 04:43 Popular Immersion heater element removal
    by Admin Added 1,512 Views / 1 Likes
    In this video Razor demonstrates how to remove an immersion heater element from a copper cylinder.
  • 05:00 Popular How to join any water pipe | Philmac UTC
    by Admin Added 2,969 Views / 1 Likes
    It is now possible to join virtually any pipe to any pipe using the philmac universal transitional coupling. You do not need to worry about the pipe being metric or imperial as the UTC an connect either pipe. The UTC’s are available in a variety of
  • 06:06 Popular How to repair a hole in a copper pipe using a click fix patch repair
    by Admin Added 399 Views / 1 Likes
    In this video I repair a hole in a copper pipe using a flowflex copper click fix 15mm pipe repair patch. These are a superb way of repairing damaged pipes as the existing copper pipe does not need to be cut in order to make the repair. These fittings are
  • 05:32 Popular How to install a basin waste
    by Admin Added 4,798 Views / 2 Likes
    Installing a basin waste can be difficult especially if you try to use the sealing washers that are supplied with the basin waste. Here we fit a pop up waste into a square vanity unit basin.
