Metalworking videos
  • 02:41 Popular Cutting steel bar
    Cutting steel bar
    by Admin Added 1,181 Views / 0 Likes
    Cutting steel bar or tube is often difficult unless you have access to a metal cutting band saw. Here we use a Dewalt D28710 metal cutting chop saw to cut a piece of 20mm square steel bar.
  • 05:41 Popular Cutting holes in metal using a hole saw
    by Admin Added 1,114 Views / 0 Likes
    Cutting holes in metal can be difficult, here we show the correct technique for doing this using a cordless drill with torque control and a good quality hole saw
  • 07:57 Popular How to use a hacksaw
    by Admin Added 1,081 Views / 1 Likes
    A hacksaw is a very handy tool when working with metal or plastics and is a cheap way to cut these materials. This video shows how to fit the blade and cut metal using a hacksaw.
  • 04:39 Popular How to use an Helicoil to repair a damaged thread
    by Admin Added 1,061 Views / 0 Likes
    Helicoils or thread inserts are very useful if a tapped hole has become stripped of it's threads. By using the thread repair kit it is possible to repair the stripped thread so that the hole can accept a threaded bolt again.
  • 03:41 Popular Cutting threaded bar
    by Admin Added 913 Views / 0 Likes
    How to cut threaded bar or threaded rod so that it is easy to get the nut onto the bar.
  • 02:55 Popular How to cut aluminium
    by Admin Added 883 Views / 0 Likes
    Cutting aluminium can be harmful if not done correctly.
  • 07:38 Popular How to use a mag base drill
    by Admin Added 835 Views / 0 Likes
    This video shows how to use a mag base drill, or magnetic base drill. Magnetic base drills are widely used in all industrial and construction environments and are one of the most useful drills that you can possibly imagine. Sometimes there is no steel for
  • 04:12 Popular Cutting steel channel with the Rage 3S
    by Admin Added 639 Views / 0 Likes
    The Evolution Rage 3s 210mm has a maximum metal cutting capacity of 6mm, but in this demonstration I cut through a piece of steel channel that measures 200mm by 100mm and is roughly 10mm thick in places. It’s not recommended to cut such large pieces
  • 05:42 Popular Cobalt step drill bits
    by Admin Added 263 Views / 0 Likes
    Cobalt step drill bits are normally more expensive than normal step drill bits that are normally made from high speed steel, in this video I test out some cobalt step drills that I purchased from bang good. I order the three step drill set as it was the o
  • 06:10 Popular Round bar centre finder | drill the centre of round bar
    by Admin Added 247 Views / 0 Likes
    Finding the centre of a round bar can be difficult and time consuming. In this video I use a round bar centre finder which can be purchased on ebay for less than £6 http://fave.co/2sdV94Q This enables you to find the centre of ant round bar, tube or
