Metalworking videos
  • 01:55 Popular Identify hardened steel
    by Admin Added 1,596 Views / 0 Likes
    How to identify hardened steel, You can easily tell if steel is hardened or not by testing it with a file.
  • 04:11 Popular Left handed drill bit to remove broken studs
    by Admin Added 1,703 Views / 1 Likes
    Removing a broken bolt or stud can be extremely difficult but in some cases such as when the bolt head has been sheared off by sideways force it is possible to remove the remainder of the bolt using a left handed drill bit. Here we demonstrate how to remo
  • 02:52 Popular Pack drilling several identical items
    by Admin Added 1,212 Views / 0 Likes
    Pack drilling is often used when several items need drilling in the same position. It is essential when pack drilling that the materials are clamped together as tightly as possible or else a piece of material in the middle of the pack could work loose and
  • 04:12 Popular Removing a broken bolt using a welder
    by Admin Added 1,541 Views / 2 Likes
    Removing a broken or sheared bolt or stud is never easy, but if you have a welder (a mig welder is preferred) you can sometimes weld a nut to the end of the broken bolt. The heat generated by the welding process often helps to loosen the bolt and makes re
    by Admin Added 2,430 Views / 1 Likes
  • 06:10 Popular Round bar centre finder | drill the centre of round bar
    by Admin Added 224 Views / 0 Likes
    Finding the centre of a round bar can be difficult and time consuming. In this video I use a round bar centre finder which can be purchased on ebay for less than £6 http://fave.co/2sdV94Q This enables you to find the centre of ant round bar, tube or
  • 04:11 Popular Speedtaps | tapping holes with an impact wrench!
    by Admin Added 1,188 Views / 0 Likes
    Speedtaps are a very fast way to tap drilled holes. The speedtaps are made from M2 steel and nitrate coated to make them extremely tough. The hexagonal heads on the speedtaps correspond with the head on the bolt so you use the same socket for the speedtap
  • 03:22 Popular Tapping threads using a cordless drill
    by Admin Added 1,634 Views / 0 Likes
    How to tap a hole using a cordless drill and a taper tap.
  • 05:04 Popular Threads in sheet metal | Rivet nuts
    by Admin Added 1,227 Views / 0 Likes
    Tapping threads into thin metal is impossible; this is where the rivet nut comes in handy. These are known by several different names including rivet nuts, riv nuts or nutserts. Once the rivet nut is expanded in the hole it leaves a permanent thread which
  • 04:28 Popular Unistrut | Vantrunk
    Unistrut | Vantrunk
    by Admin Added 1,693 Views / 0 Likes
    Unistrut or Vantrunk galvanised channel is very useful for people that wish to make things from metal, but cannot weld. This type of channel is very adaptable and can be used almost anywhere to make brackets etc.
