Metalworking videos
  • 05:04 Popular Threads in sheet metal | Rivet nuts
    by Admin Added 1,241 Views / 0 Likes
    Tapping threads into thin metal is impossible; this is where the rivet nut comes in handy. These are known by several different names including rivet nuts, riv nuts or nutserts. Once the rivet nut is expanded in the hole it leaves a permanent thread which
  • 07:34 Popular How to tap metal
    How to tap metal
    by Admin Added 2,244 Views / 0 Likes
    How to tap a threaded hole into a piece of metal
  • 02:52 Popular Pack drilling several identical items
    by Admin Added 1,228 Views / 0 Likes
    Pack drilling is often used when several items need drilling in the same position. It is essential when pack drilling that the materials are clamped together as tightly as possible or else a piece of material in the middle of the pack could work loose and
  • 04:11 Popular Speedtaps | tapping holes with an impact wrench!
    by Admin Added 1,212 Views / 0 Likes
    Speedtaps are a very fast way to tap drilled holes. The speedtaps are made from M2 steel and nitrate coated to make them extremely tough. The hexagonal heads on the speedtaps correspond with the head on the bolt so you use the same socket for the speedtap
  • 03:55 Popular Drill bits for drilling metal
    by Admin Added 1,428 Views / 0 Likes
    Metal drill types, this video is one of three on drilling metal.
  • 18:54 Popular How to make brackets | Angle brackets
    by Admin Added 1,439 Views / 0 Likes
    Heavy duty angle brackets are extremely useful; these can be used to store ladders on walls or can be used for very heavy duty shelving.
  • 05:34 Popular Blacksmiths drills
    Blacksmiths drills
    by Admin Added 1,308 Views / 0 Likes
    When drilling metal you are often restricted by the size of the drill’s chuck but by using reduced shank drill bits, often called Blacksmiths drill bits you can easily drill larger holes as long as your drill has sufficient power.
  • 02:24 Popular Drill thin metal using stepdrills
    by Admin Added 1,191 Views / 0 Likes
    Step drills are the drill bit of choice for drilling holes in thin sheet metal, these step shaped drill bits make really light work of thin material which is typically difficult to drill using standard HSS drill bits.
  • 02:41 Popular Cutting hardened steel
    by Admin Added 1,623 Views / 0 Likes
    steel can behardened by having a high carbon content, heat treatment or by work hardening. Cutting hardened steel with any type of saw is almost impossible!
  • 06:10 Popular Round bar centre finder | drill the centre of round bar
    by Admin Added 247 Views / 0 Likes
    Finding the centre of a round bar can be difficult and time consuming. In this video I use a round bar centre finder which can be purchased on ebay for less than £6 http://fave.co/2sdV94Q This enables you to find the centre of ant round bar, tube or
