Metalworking videos
  • 01:53 Popular How to use a bell punch
    by Admin Added 1,504 Views / 0 Likes
    A bell punch is designed for centre punching the exact centre of a round bar. This inexpensive tool is very useful and is often called a bell centre punch. Marking the exact centre of a round bar has never been so easy !
  • 04:24 Popular How to use Blind rivets
    by Admin Added 1,467 Views / 0 Likes
    How to use blind rivets to join two thin pieces of metal together
  • 02:32 Popular How to chamfer metal
    by Admin Added 1,463 Views / 0 Likes
    Metal can easily be chamfered using a file or angle grinder, this video shows how to chamfer a piece of laser cut metal.
    by Admin Added 1,457 Views / 1 Likes
  • 18:54 Popular How to make brackets | Angle brackets
    by Admin Added 1,440 Views / 0 Likes
    Heavy duty angle brackets are extremely useful; these can be used to store ladders on walls or can be used for very heavy duty shelving.
  • 03:55 Popular Drill bits for drilling metal
    by Admin Added 1,428 Views / 0 Likes
    Metal drill types, this video is one of three on drilling metal.
  • 06:11 Popular Cutting sheet steel using a jigsaw
    by Admin Added 1,413 Views / 0 Likes
    How to cut sheet steel using a jigsaw with a metal cutting blade.
  • 07:41 Popular How to make a chain anchor point
    by Admin Added 1,411 Views / 0 Likes
    This video shows how to make a chain securing anchor from a piece of angle iron. Using anchors like this means that if a thief does manage to break into your garage there will be nothing expensive lying around that he or she can simply grab as all equipme
  • 03:03 Popular How to drill large holes in metal
    by Admin Added 1,344 Views / 0 Likes
    Here we drill a 26mm hole through some 5mm thick mild steel using a home pillar drill and hole saw.
  • 05:34 Popular Blacksmiths drills
    Blacksmiths drills
    by Admin Added 1,308 Views / 0 Likes
    When drilling metal you are often restricted by the size of the drill’s chuck but by using reduced shank drill bits, often called Blacksmiths drill bits you can easily drill larger holes as long as your drill has sufficient power.
  • 03:47 Popular How to Chain drill steel
    by Admin Added 1,277 Views / 0 Likes
    Chain drilling is a technique that is regularly used in metalworking if you do not have a milling machine or laser cutting machine available. You can use chain drilling to cut out virtually any shape at all from metal using a simple drill. When marking ou
  • 05:04 Popular Threads in sheet metal | Rivet nuts
    by Admin Added 1,242 Views / 0 Likes
    Tapping threads into thin metal is impossible; this is where the rivet nut comes in handy. These are known by several different names including rivet nuts, riv nuts or nutserts. Once the rivet nut is expanded in the hole it leaves a permanent thread which
  • 03:01 Popular Choosing a disk for a grinder
    by Admin Added 1,237 Views / 0 Likes
    A look at some of the disks available for fixing to an angle grinder
  • 02:52 Popular Pack drilling several identical items
    by Admin Added 1,231 Views / 0 Likes
    Pack drilling is often used when several items need drilling in the same position. It is essential when pack drilling that the materials are clamped together as tightly as possible or else a piece of material in the middle of the pack could work loose and
  • 04:11 Popular Speedtaps | tapping holes with an impact wrench!
    by Admin Added 1,216 Views / 0 Likes
    Speedtaps are a very fast way to tap drilled holes. The speedtaps are made from M2 steel and nitrate coated to make them extremely tough. The hexagonal heads on the speedtaps correspond with the head on the bolt so you use the same socket for the speedtap
  • 02:24 Popular Drill thin metal using stepdrills
    by Admin Added 1,191 Views / 0 Likes
    Step drills are the drill bit of choice for drilling holes in thin sheet metal, these step shaped drill bits make really light work of thin material which is typically difficult to drill using standard HSS drill bits.
