Metalworking videos
  • 03:47 Popular How to Chain drill steel
    by Admin Added 1,308 Views / 0 Likes
    Chain drilling is a technique that is regularly used in metalworking if you do not have a milling machine or laser cutting machine available. You can use chain drilling to cut out virtually any shape at all from metal using a simple drill. When marking ou
  • 02:32 Popular How to chamfer metal
    by Admin Added 1,480 Views / 0 Likes
    Metal can easily be chamfered using a file or angle grinder, this video shows how to chamfer a piece of laser cut metal.
  • 03:49 Popular How to cut a bolt without damaging the threads
    by Admin Added 4,367 Views / 0 Likes
    This video shows how to cut a bolt using a hacksaw or a pair of electrical crimping pliers. Cutting a bolt has never been so easy!
  • 02:55 Popular How to cut aluminium
    by Admin Added 894 Views / 0 Likes
    Cutting aluminium can be harmful if not done correctly.
  • 03:43 how to drill a hole in a cast iron soil pipe
    by Admin Added 43 Views / 0 Likes
    In this video I cut a 57mm diameter hole in a cast iron soil stack pipe. This can be difficult to do as cast iron is tough compared to todays modern plastics. To cut the hole I have used a Starrett 57mm Bi-metal hole saw and arbour. Ideally this job would
  • 03:03 Popular How to drill large holes in metal
    by Admin Added 1,369 Views / 0 Likes
    Here we drill a 26mm hole through some 5mm thick mild steel using a home pillar drill and hole saw.
  • 07:41 Popular How to make a chain anchor point
    by Admin Added 1,438 Views / 0 Likes
    This video shows how to make a chain securing anchor from a piece of angle iron. Using anchors like this means that if a thief does manage to break into your garage there will be nothing expensive lying around that he or she can simply grab as all equipme
  • 08:49 Popular How to make a metal handle
    by Admin Added 1,559 Views / 0 Likes
    This video shows how to make a metal handle from a piece of 25mm*3mm flat mild steel bar, this is useful if you ever need to make a handle for something that keeps breaking as the steel will be extremely durable.
  • 18:54 Popular How to make brackets | Angle brackets
    by Admin Added 1,460 Views / 0 Likes
    Heavy duty angle brackets are extremely useful; these can be used to store ladders on walls or can be used for very heavy duty shelving.
  • 09:43 Popular How to make small vehicle ramps
    by Admin Added 1,873 Views / 1 Likes
    Moving small vehicles such as quad bikes or ride on lawn mowers can be difficult, especially if you need to move the vehicle to a different level. Here we make a pair of steel ramps, which are lined with Aluminium checker plate which means that a vehicle
  • 07:34 Popular How to tap metal
    How to tap metal
    by Admin Added 2,297 Views / 0 Likes
    How to tap a threaded hole into a piece of metal
  • 01:53 Popular How to use a bell punch
    by Admin Added 1,540 Views / 0 Likes
    A bell punch is designed for centre punching the exact centre of a round bar. This inexpensive tool is very useful and is often called a bell centre punch. Marking the exact centre of a round bar has never been so easy !
  • 07:57 Popular How to use a hacksaw
    by Admin Added 1,094 Views / 1 Likes
    A hacksaw is a very handy tool when working with metal or plastics and is a cheap way to cut these materials. This video shows how to fit the blade and cut metal using a hacksaw.
  • 07:38 Popular How to use a mag base drill
    by Admin Added 867 Views / 0 Likes
    This video shows how to use a mag base drill, or magnetic base drill. Magnetic base drills are widely used in all industrial and construction environments and are one of the most useful drills that you can possibly imagine. Sometimes there is no steel for
  • 05:34 Popular How to use a screw extractor/easyout
    by Admin Added 1,785 Views / 0 Likes
    Screw extractors are often called easyouts, these can be used to remove a broken bolt or a broken stud from a tapped hole. Here we demonstrate how to use the screw extractor to remove a broken bolt from a shaft.
  • 04:39 Popular How to use an Helicoil to repair a damaged thread
    by Admin Added 1,078 Views / 0 Likes
    Helicoils or thread inserts are very useful if a tapped hole has become stripped of it's threads. By using the thread repair kit it is possible to repair the stripped thread so that the hole can accept a threaded bolt again.
