Metalworking videos
  • 03:49 Popular How to cut a bolt without damaging the threads
    by Admin Added 4,616 Views / 0 Likes
    This video shows how to cut a bolt using a hacksaw or a pair of electrical crimping pliers. Cutting a bolt has never been so easy!
    by Admin Added 2,584 Views / 1 Likes
  • 07:34 Popular How to tap metal
    How to tap metal
    by Admin Added 2,388 Views / 0 Likes
    How to tap a threaded hole into a piece of metal
  • 07:12 Popular drill metal with a  pillar drill
    by Admin Added 2,331 Views / 0 Likes
    drill metal using a pillar drill
  • 04:44 Popular Cobalt drill bits
    Cobalt drill bits
    by Admin Added 1,976 Views / 0 Likes
    Cobalt drills are excellent at drilling through hard metals, they can often drill tough metals that a normal High speed steel drill bit cannot drill.
  • 09:43 Popular How to make small vehicle ramps
    by Admin Added 1,940 Views / 1 Likes
    Moving small vehicles such as quad bikes or ride on lawn mowers can be difficult, especially if you need to move the vehicle to a different level. Here we make a pair of steel ramps, which are lined with Aluminium checker plate which means that a vehicle
  • 05:34 Popular How to use a screw extractor/easyout
    by Admin Added 1,840 Views / 0 Likes
    Screw extractors are often called easyouts, these can be used to remove a broken bolt or a broken stud from a tapped hole. Here we demonstrate how to use the screw extractor to remove a broken bolt from a shaft.
  • 04:11 Popular Left handed drill bit to remove broken studs
    by Admin Added 1,822 Views / 1 Likes
    Removing a broken bolt or stud can be extremely difficult but in some cases such as when the bolt head has been sheared off by sideways force it is possible to remove the remainder of the bolt using a left handed drill bit. Here we demonstrate how to remo
  • 03:22 Popular Tapping threads using a cordless drill
    by Admin Added 1,784 Views / 0 Likes
    How to tap a hole using a cordless drill and a taper tap.
  • 04:28 Popular Unistrut | Vantrunk
    Unistrut | Vantrunk
    by Admin Added 1,783 Views / 0 Likes
    Unistrut or Vantrunk galvanised channel is very useful for people that wish to make things from metal, but cannot weld. This type of channel is very adaptable and can be used almost anywhere to make brackets etc.
  • 03:43 Popular Drilling hardened steel with ARTU drill bits
    by Admin Added 1,710 Views / 1 Likes
    Drilling through hardened steel is now possible using ARTU multipurpose drill bits.
  • 07:12 Popular Drilling metal
    Drilling metal
    by Admin Added 1,695 Views / 0 Likes
    Drilling metal is not too difficult as long as you use the correct equipment. Here we showhow to drill steel using a hand drill and HSS drill bit.
  • 02:41 Popular Cutting hardened steel
    by Admin Added 1,686 Views / 0 Likes
    steel can behardened by having a high carbon content, heat treatment or by work hardening. Cutting hardened steel with any type of saw is almost impossible!
  • 04:12 Popular Removing a broken bolt using a welder
    by Admin Added 1,681 Views / 2 Likes
    Removing a broken or sheared bolt or stud is never easy, but if you have a welder (a mig welder is preferred) you can sometimes weld a nut to the end of the broken bolt. The heat generated by the welding process often helps to loosen the bolt and makes re
  • 01:55 Popular Identify hardened steel
    by Admin Added 1,661 Views / 0 Likes
    How to identify hardened steel, You can easily tell if steel is hardened or not by testing it with a file.
  • 08:49 Popular How to make a metal handle
    by Admin Added 1,622 Views / 0 Likes
    This video shows how to make a metal handle from a piece of 25mm*3mm flat mild steel bar, this is useful if you ever need to make a handle for something that keeps breaking as the steel will be extremely durable.
