Lock repair videos
  • 05:18 Popular ABS secure euro cylinder
    by Admin Added 1,611 Views / 0 Likes
    Most Euro cylinder locks can be broken into in minutes, but the Avocet ABS high security cylinder is different.
  • 08:50 Popular Enfield Garage door bolt installation
    by Admin Added 3,834 Views / 0 Likes
    Enfield garage door bolts are a quick and easy way to secure your existing garage door.
  • 01:45 Popular Euro cylinder lock snapping
    by Admin Added 2,438 Views / 0 Likes
    Euro cylinder locks can be very insecure, this video shows how to snap a euro cylinder from inside the property. This is useful if you ever lose the keys to a lock
  • 02:06 Popular How to change a euro cylinder
    by Admin Added 1,249 Views / 0 Likes
    Euro cylinders are normally pretty easy to change, this video shows how
    by Admin Added 1,894 Views / 0 Likes
  • 10:36 Popular How to fix a broken key in a Euro cylinder lock
    by Admin Added 803 Views / 0 Likes
    A broken key in a euro cylinder lock can be a bit daunting at first but in many cases it is an easy fix. If you can remove the old broken key you can get another key cut, or if you can’t get the key out you can remove the euro cylinder for a like fo
  • 03:43 Popular How to measure a Euro cylinder
    by Admin Added 755 Views / 0 Likes
    Euro cylinder locks are now very common but there are hundreds of different lengths available. The cylinders normally go up in 5mm increments. This video shows two ways of measuring a euro cylinder, one with the cylinder in the door and the other with the
  • 06:32 Popular How to replace a French door lock
    by Admin Added 2,216 Views / 0 Likes
    French door’s normally rely on two keyed alike euro cylinders to lock them. Replacing one of the cylinders is easy, but the other one is a bit more difficult as you have to remove the keeper plate and often drill a hole through the internal PVC prof
  • 07:05 Popular How to replace a multipoint lock
    by Admin Added 1,488 Views / 2 Likes
    This video shows how to replace the multipoint lock in a UPVC door. These locks are now very common and are normally reliable but eventually they can wear out and will need replacing. The cost of a new multipoint lock was £50 from the local locksmit
  • 03:13 Popular Thumb turn Euro cylinders
    by Admin Added 714 Views / 0 Likes
    Thumb turn euro cylinders are often a good idea for many properties as they mean that it will always be possible to get in the property as long as you have the key. With most normal euro cylinders if someone leaves the key in the lock on the inside of the
