Home Security videos
Home security has never been more important.
Each year thousands of homes are broken into or vandalised. Much of this can be prevented by making it as hard as possible for any potential thief’s or vandals. These videos will show how to improve the security of your own home easily and quickly.
  • 05:18 Popular ABS secure euro cylinder
    by Admin Added 1,651 Views / 0 Likes
    Most Euro cylinder locks can be broken into in minutes, but the Avocet ABS high security cylinder is different.
  • 04:01 Popular Burglar alarm battery replacement
    by Admin Added 2,147 Views / 2 Likes
    This video shows how to replace the back up battery in a domestic burglar alarm. If the battery goes flat and there is a power cut the alarm will sound when the power is restored.
  • 02:07 Popular Clutch head screws
    Clutch head screws
    by Admin Added 1,273 Views / 0 Likes
    Security screws such as clutch head screws can make it much more difficult for any potential thief to enter a property in the first place. These screws can only be driven in one direction which makes removing them difficult without specialist tools.
  • 03:42 Popular Dummy burglar alarm flashing box
    by Admin Added 1,876 Views / 0 Likes
    Burglars do not like being disturbed, if you use a flasher unit in your dummy bell box a burglar will not know for sure if it is real or not.
  • 08:50 Popular Enfield Garage door bolt installation
    by Admin Added 3,895 Views / 0 Likes
    Enfield garage door bolts are a quick and easy way to secure your existing garage door.
  • 01:45 Popular Euro cylinder lock snapping
    by Admin Added 2,498 Views / 0 Likes
    Euro cylinder locks can be very insecure, this video shows how to snap a euro cylinder from inside the property. This is useful if you ever lose the keys to a lock
  • 08:23 Popular Homemonitor HD pro Wi-Fi video camera install
    by Admin Added 2,296 Views / 0 Likes
    The Homemonitor HD Pro Wi-Fi video camera is installed in this video. This camera has to be the easiest camera ever to install and set up as it can be done simply by using an Ethernet cable and a POE injector/powered Ethernet switch. Once installed you ca
  • 04:29 Popular How to fit a door viewer | spy hole
    by Admin Added 1,841 Views / 0 Likes
    This video shows how to quickly install a door viewer (often called a spy hole) into a solid wood door.
  • 07:41 Popular How to make a chain anchor point
    by Admin Added 1,523 Views / 0 Likes
    This video shows how to make a chain securing anchor from a piece of angle iron. Using anchors like this means that if a thief does manage to break into your garage there will be nothing expensive lying around that he or she can simply grab as all equipme
  • 01:40 Popular How to use Shear nuts
    by Admin Added 1,384 Views / 0 Likes
    Here I demonstrate how shear nuts work, these anti-theft nuts are extremely good for bolting down items in public places which could possibly be stolen such as benches in parks etc. Shear nuts are available in various thread sizes and are available in sta
  • 05:59 Popular Reolink RLC-410 4MP PoE Security IP Camera review including how to install
    by Admin Added 422 Views / 0 Likes
    The Reolink RLC-410 is a 4MP PoE Security camera, this camera is very easy to set up as it work via POE (power over ethernet). All you need to get this camera working is an internet connection and router, preferably with POE or you can use a separate POE
    by Admin Added 2,992 Views / 1 Likes
  • 06:10 Popular Shed door securing bar
    by Admin Added 1,703 Views / 1 Likes
    Shed doors can be particularly vulnerable to attack from the opportunist thief. Unfortunately many shed locks are easy to bypass and many can be removed in minutes using basic tools. Here I construct a bar to span the set of double doors on this shed usin
  • 10:51 Popular Y Cam | Wireless CCTV | Home Monitor
    by Admin Added 2,441 Views / 1 Likes
    Home monitor by Y cam is a brilliant solution for watching internal rooms using your wireless internet connection. Upon movement the Y cam starts to film and sends the images via your wireless connectio to their server, where you can log on to from anywhe
