Fasteners and fixings are an integral part of DIY, this section has a large amount of videos showing how to fix to most substrates including plasterboard, tiles and concrete.
  • 04:33 Popular GripIt fixings
    GripIt fixings
    by Admin Added 740 Views / 0 Likes
    GripIt fixings are a quick and easy way of fixing to plasterboard or drywall. These fixings are easy to use and currently come in four different sizes depending on what you are fixing to the plasterboard or drywall. Currently 4 different GripIt fixing are
  • 03:42 Popular Space-Plugs
    Space-Plugs
    by Admin Added 729 Views / 0 Likes
    Space-plugs are a very quick and easy way of fitting kitchen units to walls or items to insulated plaster walls very quickly. Space plugs come in two different sizes and can easily be adjusted to fit any void between the item being fixed and the wall. Tha
  • 13:39 Popular How to remove a broken bolt in a deep hole | remove broken bolt in recessed hole
    by Admin Added 489 Views / 0 Likes
    It can be difficult removing a broken bolt or stud that is recessed in a deep hole as there are not many techniques to remove the bolts. Before attempting to remove any bolt, it is a good idea to shock the bolt first, then apply some heat and finally some
  • 13:47 Popular How to remove rounded Allen head bolts - the complete guide
    by Admin Added 380 Views / 0 Likes
    In this video I demonstrate some of the techniques that we use regularly on site to remove rounded Allen head bolts, or hex key head bolts. Allen head bolts can be difficult to remove as dirt can get compressed into the head which means the minute you ins
  • 06:58 Popular How to fix a shelf to a dot and dab wall using corefix fixings
    by Admin Added 365 Views / 0 Likes
    In this video I fix a floating shelf to a dot and dab wall, if you are not familiar with a dot and dabbed wall (direct bond method), there is an article here, which explains about it- http://www.ultimatehandyman.co.uk/how-to/plastering/direct-bond Fixing
