Fasteners and fixings are an integral part of DIY, this section has a large amount of videos showing how to fix to most substrates including plasterboard, tiles and concrete.
  • 13:39 Popular How to remove a broken bolt in a deep hole | remove broken bolt in recessed hole
    by Admin Added 489 Views / 0 Likes
    It can be difficult removing a broken bolt or stud that is recessed in a deep hole as there are not many techniques to remove the bolts. Before attempting to remove any bolt, it is a good idea to shock the bolt first, then apply some heat and finally some
  • 01:48 Popular How to use concrete screws
    by Admin Added 2,370 Views / 0 Likes
    Concrete screws are a really fast and easy way to fix to concrete
  • 04:33 Popular GripIt fixings
    GripIt fixings
    by Admin Added 1,418 Views / 0 Likes
    GripIt fixings are a quick and easy way of fixing to plasterboard or drywall. These fixings are easy to use and currently come in four different sizes depending on what you are fixing to the plasterboard or drywall. Currently 4 different GripIt fixing are
  • 02:46 Popular Installing signs using silicone
    by Admin Added 1,167 Views / 0 Likes
    Signs are a common feature in our lives. Fitting many of them is easy if you use silicone sealant as an adhesive
  • 04:10 Popular How to install a bathroom cabinet on a stud partition wall
    by Admin Added 1,352 Views / 1 Likes
    In this video I install a bathroom cabinet with mirrored doors onto a plasterboard wall that is only three inches thick, often called an egg box partition because the plasterboard is filled with pieces of cardboard. A cabinet like this can be heavy once f
