DIY videos from Ultimate Handyman
Fasteners and fixings are an integral part of DIY, this section has a large amount of videos showing how to fix to most substrates including plasterboard, tiles and concrete.
  • 04:41 Popular How to fix to an insulated wall
    by Admin Added 1,037 Views / 2 Likes
    Fixing to an insulated wall can be very difficult. In this demonstration I use space-plugs to bridge the gap between the item being fixed and the external wall. Fixing to an insulated wall is much easier if you use the space plugs. Thanks to Rob from Colo
  • 08:30 Popular How to fix to plasterboard
    by Admin Added 7,783 Views / 1 Likes
    Plasterboard fixings are wide and varied, here we take a look at a few different types
  • 04:10 Popular How to install a bathroom cabinet on a stud partition wall
    by Admin Added 1,405 Views / 1 Likes
    In this video I install a bathroom cabinet with mirrored doors onto a plasterboard wall that is only three inches thick, often called an egg box partition because the plasterboard is filled with pieces of cardboard. A cabinet like this can be heavy once f
  • 13:39 Popular How to remove a broken bolt in a deep hole | remove broken bolt in recessed hole
    by Admin Added 557 Views / 0 Likes
    It can be difficult removing a broken bolt or stud that is recessed in a deep hole as there are not many techniques to remove the bolts. Before attempting to remove any bolt, it is a good idea to shock the bolt first, then apply some heat and finally some
  • 01:19 Popular How to remove hollow wall anchors
    by Admin Added 1,042 Views / 0 Likes
    Hollow wall anchors can be difficult to remove if you don’t know how to remove them. In this video a hollow wall anchor is removed by simply inserting the screw and then giving the screw a few gentle taps with a hammer. Hollow wall anchors also come
  • 13:47 Popular How to remove rounded Allen head bolts - the complete guide
    by Admin Added 440 Views / 0 Likes
    In this video I demonstrate some of the techniques that we use regularly on site to remove rounded Allen head bolts, or hex key head bolts. Allen head bolts can be difficult to remove as dirt can get compressed into the head which means the minute you ins
  • 02:17 Popular How to use a hollow wall anchor setting tool
    by Admin Added 1,279 Views / 0 Likes
    Hollow wall anchors such as rawlplug intersets or Mollys can sometimes be installed without using the special setting tool, but in drywall that is not plastered the setting tool is essential. The cost of the hollow wall anchor setting tool is about £
  • 04:24 Popular How to use Blind rivets
    by Admin Added 1,576 Views / 0 Likes
    How to use blind rivets to join two thin pieces of metal together
  • 04:47 Popular How to use Concrete anchors
    by Admin Added 2,179 Views / 0 Likes
    Concrete anchors are very common and if used correctly can be a very useful fixing
  • 01:48 Popular How to use concrete screws
    by Admin Added 2,450 Views / 0 Likes
    Concrete screws are a really fast and easy way to fix to concrete
  • 04:58 Popular How to use resin fixings
    by Admin Added 3,418 Views / 1 Likes
    Resin fixings are a great way of fixing to most solid substrates
  • 04:04 Popular How to use Rigifix wall anchors
    by Admin Added 3,534 Views / 0 Likes
    Rigifix wall anchors are designed for fixing heavy items to drylined solid walls
  • 01:40 Popular How to use Shear nuts
    by Admin Added 1,443 Views / 0 Likes
    Here I demonstrate how shear nuts work, these anti-theft nuts are extremely good for bolting down items in public places which could possibly be stolen such as benches in parks etc. Shear nuts are available in various thread sizes and are available in sta
  • 01:52 Popular How to use Spring toggles
    by Admin Added 1,378 Views / 0 Likes
    Here we demonstrate spring toggles in plasterboard
  • 09:26 Popular How to use wall plugs | wall plug tips
    by Admin Added 3,012 Views / 7 Likes
    Wall plugs are one of the most commonly used fixings for solid walls. Wall plugs often called rawl plugs can be used to fix items to brick, stone and concrete. However wall plugs do not work too well in aerated concrete and so it’s better if you can
  • 02:46 Popular Installing signs using silicone
    by Admin Added 1,196 Views / 0 Likes
    Signs are a common feature in our lives. Fitting many of them is easy if you use silicone sealant as an adhesive
